Normal oil pressure
My oil is at the normal level for my H22 and my oil pressure gauge has been reading about 65psi at 3k rpm and about 15psi at 700rpm someone told me that was a bit low so what's normal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi »</TD></TR><TR><TD CLASS="quote">I just put a H22A into my 95 Si. Those readings are pretty close to my car. I say your ok.
Also, I get to 75ish at WOT</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92si »</TD></TR><TR><TD CLASS="quote">Spec is:
No less than 7psi @ Idle
No less than 50psi @ 3000rpm</TD></TR></TABLE>
that seems really low at 3000, where did you read that
u can try a smaller oil filter for a higher oil pressure. i think.
or, you can add like 3-4 more quarts of oil
just kidding
try the smaller oil filter. it will not filter as well, but it will keep pressure up.
just kiddingtry the smaller oil filter. it will not filter as well, but it will keep pressure up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 »</TD></TR><TR><TD CLASS="quote">
that seems really low at 3000, where did you read that</TD></TR></TABLE>
it is the minimum allowable oil pressure, per the service manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 »</TD></TR><TR><TD CLASS="quote">what difference will slightly higher oil pressure do though?</TD></TR></TABLE>
keep everything properly lubricated, could be the difference between vtec and limp mode...no performance gains, just engine reliability/health
s2kkid
Apr 12, 2005 03:50 PM
