REtune up, on a stock motor..... need some extra tips
Old Apr 3, 2005 | 09:45 PM
Vinhtran17's Avatar
Default REtune up, on a stock motor..... need some extra tips
im just doing another swap, ls motor, but before i put the new used block (35 k)
is there anything else i jsut replace while im haveing the block out? as of right now i have new water pump, timing belt, oil pump, spark plugs, dizzy, rotor, thermostat, headgasket, cam seals, and the fluids and oil.
is there anything else im missing that i should replace besides whats above?
thanks
Old Apr 3, 2005 | 10:29 PM
PandaBear's Avatar
Default Re: REtune up, on a stock motor..... need some extra tips (Vinhtran17)
Just make sure the rest of the stuff suppose to be there is there, like TB cover, T belt tensioner, etc. You are doing more than what most of us would do to a 35k engine, good luck with it.
Old Apr 4, 2005 | 07:07 PM
Vinhtran17's Avatar
thanks, just wanted to make sure what i tune up now will be easy, compare to when is actually in the car... but yeah thanks.
is any other comments?
Old Apr 5, 2005 | 10:51 AM
PandaBear's Avatar
Default Re: (Vinhtran17)
35k is pretty new, I wouldn't worry too much about the stuff outside what you mentioned. But if the car you swap in is old (6 year, 90k, etc), then maybe it is time to replace a few things like hoses, check if the radiator is cracked, if CV joint is bad, etc.
Glad you are on the carefull side, and I am sure you will be alright.
Old Apr 5, 2005 | 10:56 AM
Racermech's Avatar
Default Re: (PandaBear)
if you want i would slap in the energy suspension firewall mount. It is a big PITA to do it later.
Old Apr 5, 2005 | 12:41 PM
Vinhtran17's Avatar
thanks alot guys.
Old Apr 5, 2005 | 12:42 PM
Vinhtran17's Avatar
oh yeah, should i run some seafoam in my new engine anyways while im at it, just to get rid of any carbon build up?
Old Apr 9, 2005 | 09:36 PM
Vinhtran17's Avatar
i think that sea foam can be a danger when it comes to highmileage car, but im not really sure about low mileage cars.. what do you guy think of it?
Old Apr 9, 2005 | 09:41 PM
PLAGUED_DB7's Avatar
injectors, all fuses.
I would check the bearings just to be safe...
Old Apr 10, 2005 | 10:11 AM
Racermech's Avatar
Default Re: (PLAGUEDDB7)
Unless the car was run rich, or run hard I dont think a 35k motor would need sea foam right now.
I would go ahead bolt it in and run it for a few days jsut to see how everything is running. Then deciede if you need to run the sea foam
grizbait
14
Mar 11, 2010 10:56 AM
phanatic
May 30, 2006 06:42 PM
99exd16y8
Jun 9, 2005 09:49 AM
juicedricer
Feb 12, 2003 01:34 PM
deviant1
Dec 24, 2002 06:05 PM
