Rattling pipes
Old Apr 3, 2005 | 08:52 PM
lastpunkinline's Avatar
Default Rattling pipes
There this annoying rattling this underneath my car, i have had several suggestions that it could be my caty converter, some inside piping(i dunno wut that means) but i would much appreciate honda-tech's opinion. The rattling is getting more constant and im starting to hear it at high speeds as opposed to only hearing it at very low rpm's.
Old Apr 6, 2005 | 10:53 AM
Samosagison's Avatar
Try checking the heat shield around your cat. That would rattle on my gsr at mid rpm.
Old Apr 6, 2005 | 11:11 AM
SiR AuToBoT's Avatar
Default Re: (Samosagison)
its most likely is the cat converter
my buds DB8 was like that and when we took out the cat converter
the honeycomb inside was broken to pieces, we just broke some more and pour it out and it was fine
BTW it ran alot smooother after that, remember there are 2 section in the cat, we just broke off one side of it not both, if we did that it would be like running on a straight pipe.
hope this help
Old Apr 6, 2005 | 11:28 AM
simon98h22's Avatar
Default Re: (SiR AuToBoT)
Check the heatshield around your exhaust. If a portion is rotten or has come loose, it will vibrate against your piping and the noise is very annoying, like a tin-ee rattle. Mine only did it at certain RPMS. Just use tin snips and cut the bad portion out. Move onto the cat once you've ruled this out.
Si
Old Apr 6, 2005 | 11:39 AM
Integra GSR 95's Avatar
It is a good possiblity the insides of the cat have rusted out like my old honda or the Heat shield as other have mentioned.
Old Apr 6, 2005 | 12:28 PM
Tuesdaynightfever's Avatar
Cat. converter heatshield. That's what mine is...I just turn my music up louder
Old Apr 6, 2005 | 01:07 PM
XSIWANNAB's Avatar
Default Re: (Tuesdaynightfever)
two things1)heat shield like everyone else is saying,(2)maybe u could even check your hangers,they could be broken
Old Apr 7, 2005 | 07:48 AM
Rpizzle's Avatar
Default Re: Rattling pipes (lastpunkinline)
Its the heat shield above the cat, I removed mine on my own, but then your floorboard is going to heat up
ef8-dc2619
Nov 11, 2011 09:26 PM
JDMEK9R
Jan 9, 2008 10:58 AM
Voodooboy520
14
Aug 14, 2006 01:52 PM
Cyber ITR
Jan 8, 2004 10:01 AM
SymphonyX
11
May 8, 2003 08:58 AM
