120mph traps decent for a stock gsr block???
Old Apr 3, 2005 | 07:51 PM
joepiscapo_83's Avatar
Default UPDATED..12psi & 120mph traps decent for a stock gsr block???
threw a completely stock gsr block into my 94 civic eg hatch just to see what i could run this weekend. well i ran a 12.2 @ 115 my first run and 12.3 @ 120 on my second. im running a t3/t67 .82 a/r and 12 lbs of boost. didnt have time to get my 3" exhaust installed so i was still on the crappy 2.5". was also sporting 22" slicks...i wouldve been better off with some 24.5" slicks but oh well. aem ems for management...pretty conservative tune. i think it did pretty good for all it had...what do you think??? shouldve seen 11's on that 120 trap...i dont know what happened!!!!
what is the fastest time so far on a stock honda/acura block??? anyone know???
Modified by v8killr83 at 9:05 PM 4/10/2005
Old Apr 3, 2005 | 08:28 PM
SiRkid's Avatar
Default Re: 12psi & 120mph traps decent for a stock gsr block??? (v8killr83)
thats good.
there is some guy in the 10's on a completely stock turbo b16 iirc.
its fully set up to use the power though(and very light)
Old Apr 3, 2005 | 08:45 PM
Timmay's Avatar
the ******* car moves that is for sure
alot better than my gay 14.3
Old Apr 3, 2005 | 08:49 PM
SOHC_MShue's Avatar
Default Re: 12psi & 120mph traps decent for a stock gsr block??? (Timmay)
damn 14.3...must have spun your *** off right?
Old Apr 3, 2005 | 08:52 PM
Timmay's Avatar
Default Re: 12psi & 120mph traps decent for a stock gsr block??? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">damn 14.3...must have spun your *** off right?</TD></TR></TABLE>
94 LX 4 door with 98 US ITR motor, ebay intake and open stock header
2.1 60', 14.3@95.. i hate elevation, ******* idaho
i know my car has 13's in it
Old Apr 3, 2005 | 09:36 PM
i know it has 13's in it too. we need yo get your e-brake working so you can heat those slicks up better man...lol! youll get 13's before you know it. actually, get that b16 in there and boost the **** out of it...**** 13's.
Old Apr 3, 2005 | 09:44 PM
Timmay's Avatar
11's on stock b16a block here i come
Old Apr 3, 2005 | 09:56 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">94 LX 4 door with 98 US ITR motor, ebay intake and open stock header
i know my car has 13's in it</TD></TR></TABLE>
oh nevermind i thought you had a turbo B in there
Old Apr 3, 2005 | 10:09 PM
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">oh nevermind i thought you had a turbo B in there </TD></TR></TABLE>
not yet, im switching my ITR motor next weekend for a b16a2 then boost
if i only get 14.3 i will wreck it
Old Apr 3, 2005 | 10:14 PM
92eh3si's Avatar
pretty good time.. i would like to see some 11's tho with them slicks and 3 inch exhaust..
u beat me tho..
check my sig
Old Apr 3, 2005 | 10:15 PM
808 NA1's Avatar
Awesome times for a stock block. Is the head stock too, or is it ported? How much horsepower are you making? My friend did a best of 11.08 on a stock GSR motor, stock ECU w/440CC RCs, FMU, and VAFC. Im not sure on his exact MPH.
Old Apr 3, 2005 | 10:18 PM
IntegracinGSR's Avatar
Is this with an open diff or LSD? if LSD, which one are ya running?
Old Apr 3, 2005 | 10:22 PM
racinskittle's Avatar
Default Re: (IntegracinGSR)
120 on stock block GSR is ****** nuts!
Old Apr 3, 2005 | 10:27 PM
Makdaddynuge's Avatar
yeah nsxmatt runs 11.7 with 115 mph traps i think
Old Apr 4, 2005 | 03:36 AM
97hb's Avatar
120 traps on stock block. A couple more pounds and I am there
Old Apr 4, 2005 | 05:54 AM
RA166E's Avatar
Congrats on the nice numbers!!!! Can't wait to see the good motor in there. That stock engine is way impressive.
Later Russell from Coeur d' Alene
Old Apr 4, 2005 | 05:55 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">11's on stock b16a block here i come</TD></TR></TABLE>
Me too
Old Apr 4, 2005 | 06:15 AM
TurboJesse
Guest
Posts: n/a
Default Re: 12psi & 120mph traps decent for a stock gsr block??? (tgreaves)
i went 121 with a stock b16 in a del sol...shitty et though
Old Apr 4, 2005 | 06:20 AM
tgreaves's Avatar
Default Re: 12psi & 120mph traps decent for a stock gsr block??? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">i went 121 with a stock b16 in a del sol...shitty et though </TD></TR></TABLE>
What ET? What 60'?
Old Apr 4, 2005 | 06:30 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
What ET? What 60'?</TD></TR></TABLE>
13.1... don't remember 60ft. Car had shitty coilovers with stock struts and was on Azenis's....wheel hopped like a bitch
Old Apr 4, 2005 | 06:49 AM
deftones0817's Avatar
You should be having better ets unless your spinning those slicks alot creating the mph. I went 12.42 @ 116 on 4 psi and then 11.76 @ 7 psi on a stock gsr with a ported head and ctr cams on 22 inch slicks. I just upgraded 24.5 because i was shifting into 5th at the 1000 mark. Are you shifting into fifth or bouncing of rev limiter?
Josh
Old Apr 4, 2005 | 07:25 AM
Boostage's Avatar
Ron sudol ran 10.9@130 on a stock gsr block in his hatch, then ran 11.2 on another stock gsr motor in a full interior and caged ex coupe, but trapped only 127
Old Apr 4, 2005 | 10:56 AM
Timmay's Avatar
Default Re: 12psi & 120mph traps decent for a stock gsr block??? (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">You should be having better ets unless your spinning those slicks alot creating the mph. I went 12.42 @ 116 on 4 psi and then 11.76 @ 7 psi on a stock gsr with a ported head and ctr cams on 22 inch slicks. I just upgraded 24.5 because i was shifting into 5th at the 1000 mark. Are you shifting into fifth or bouncing of rev limiter?
Josh</TD></TR></TABLE>
yea he is getting shitty 60's and he misses gears alot, lol
Old Apr 4, 2005 | 11:52 AM
yes, stock b16a head with gsr cams. all on open diff gsr tranny. and yes timmay, i did miss gears a few times that day huh..lol!!!
Old Apr 4, 2005 | 11:55 AM
turboEGhatch's Avatar
How does boost come on with that .82 A/R housing? What hot side? I went to the track on Friday searching for some 11's on 205/50/15 BFG DR's but I didn't get there, I suck at driving
