120mph traps decent for a stock gsr block???
UPDATED..12psi & 120mph traps decent for a stock gsr block???
threw a completely stock gsr block into my 94 civic eg hatch just to see what i could run this weekend. well i ran a 12.2 @ 115 my first run and 12.3 @ 120 on my second. im running a t3/t67 .82 a/r and 12 lbs of boost. didnt have time to get my 3" exhaust installed so i was still on the crappy 2.5". was also sporting 22" slicks...i wouldve been better off with some 24.5" slicks but oh well. aem ems for management...pretty conservative tune. i think it did pretty good for all it had...what do you think??? shouldve seen 11's on that 120 trap...i dont know what happened!!!!
what is the fastest time so far on a stock honda/acura block??? anyone know???
Modified by v8killr83 at 9:05 PM 4/10/2005
Re: 12psi & 120mph traps decent for a stock gsr block??? (v8killr83)
thats good.
there is some guy in the 10's on a completely stock turbo b16 iirc.
its fully set up to use the power though(and very light)
Re: 12psi & 120mph traps decent for a stock gsr block??? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">damn 14.3...must have spun your *** off right?</TD></TR></TABLE>
94 LX 4 door with 98 US ITR motor, ebay intake and open stock header
2.1 60', 14.3@95.. i hate elevation, ******* idaho
i know my car has 13's in it
Re: 12psi & 120mph traps decent for a stock gsr block??? (Timmay)
i know it has 13's in it too. we need yo get your e-brake working so you can heat those slicks up better man...lol! youll get 13's before you know it. actually, get that b16 in there and boost the **** out of it...**** 13's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">94 LX 4 door with 98 US ITR motor, ebay intake and open stock header
i know my car has 13's in it</TD></TR></TABLE>
oh nevermind i thought you had a turbo B in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">oh nevermind i thought you had a turbo B in there </TD></TR></TABLE>
not yet, im switching my ITR motor next weekend for a b16a2 then boost
if i only get 14.3 i will wreck it
Awesome times for a stock block. Is the head stock too, or is it ported? How much horsepower are you making? My friend did a best of 11.08 on a stock GSR motor, stock ECU w/440CC RCs, FMU, and VAFC. Im not sure on his exact MPH.
Congrats on the nice numbers!!!! Can't wait to see the good motor in there. That stock engine is way impressive.
Later Russell from Coeur d' Alene
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">11's on stock b16a block here i come</TD></TR></TABLE>
Me too
Me too
Re: 12psi & 120mph traps decent for a stock gsr block??? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">i went 121 with a stock b16 in a del sol...shitty et though </TD></TR></TABLE>
What ET? What 60'?
What ET? What 60'?
Guest
Posts: n/a
Re: 12psi & 120mph traps decent for a stock gsr block??? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
What ET? What 60'?</TD></TR></TABLE>
13.1... don't remember 60ft. Car had shitty coilovers with stock struts and was on Azenis's....wheel hopped like a bitch
You should be having better ets unless your spinning those slicks alot creating the mph. I went 12.42 @ 116 on 4 psi and then 11.76 @ 7 psi on a stock gsr with a ported head and ctr cams on 22 inch slicks. I just upgraded 24.5 because i was shifting into 5th at the 1000 mark. Are you shifting into fifth or bouncing of rev limiter?
Josh
Josh
Ron sudol ran 10.9@130 on a stock gsr block in his hatch, then ran 11.2 on another stock gsr motor in a full interior and caged ex coupe, but trapped only 127
Re: 12psi & 120mph traps decent for a stock gsr block??? (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 »</TD></TR><TR><TD CLASS="quote">You should be having better ets unless your spinning those slicks alot creating the mph. I went 12.42 @ 116 on 4 psi and then 11.76 @ 7 psi on a stock gsr with a ported head and ctr cams on 22 inch slicks. I just upgraded 24.5 because i was shifting into 5th at the 1000 mark. Are you shifting into fifth or bouncing of rev limiter?
Josh</TD></TR></TABLE>
yea he is getting shitty 60's and he misses gears alot, lol
yes, stock b16a head with gsr cams. all on open diff gsr tranny. and yes timmay, i did miss gears a few times that day huh..lol!!!
How does boost come on with that .82 A/R housing? What hot side? I went to the track on Friday searching for some 11's on 205/50/15 BFG DR's but I didn't get there, I suck at driving
