BOGGING PROBLEM PLEASE HELP!!!
I swapped over a OBD1 b16a1 into my 96 GSR i am running my OBD2 ecu and it ran fine for about 3 months. Now its bogging from 1k-5k rpm anything after that is fine. I decided to try a OBD1 b16 ecu w/ the conversion harness to try it out, but the same result. I checked spark plugs, wires, and fuel injectors they are all good. Can someone help me troubleshoot this problem. thanks
i got the same problem, i put obd1 b16 into my ls integra and it boggs like crazy when im tryin to get out of first gear and even second, but it doesnt stall. i just hit the gas and it goes i guess after all the gas is burned up inside the motor. can anyone help me out.
my 1992 gsr was doing the same..my friend advanced my timing by moving my distributor forward..worked like a charm..but dont move it too far..
y0o0orey
11
Aug 3, 2009 08:12 PM
