my car is acting very odd!!!
Ok... here's the problem, my car runs fine when i'm going and on the gas, but when i first start it and take off in first ( sometimes in 2nd gear ) it will feel like it is cutting out and kind of sputter, then i give it more gas and it goes just fine after that. The motor is pretty stock for the moment ( i just took out my skunk2 stage II cams ) and now its just bolt ons on the motor with gsr cams.
Like i said it only does it once in awhile and it will only do it for a second then stop and not do it again til i start it again after its cooled down.
Does anyone have a clue as to what this may be? I am changing the plugs later today and hope that will make it better, but i honestly have no clue why it does it.
It also idles super low sometimes and will die once in awhile when i put it in nuetral, but not all the time.
Please help me if you can!!
THE TIMING IS SET AT THE STOCK 16 DEGREES, AND WAS JUST JUST DONE BY MY TECH ABOUT 1 WEEK AGO. I PUT IN SOME OCTANE BOOSTER IN IT AND SINCE IT HAS BEEN RUNNING LIKE THIS. TPS WAS FINE TOO.
AND YOU REALLY THINK THE FUEL FILTER WOULD MAKE IT DO THIS? I WILL CHANGE IT BUT IT JUST DOESN'T SEEM LIKE IT IS THAT, BUT IF IT IS I WILL FEEL LIKE A DUMB ***.
THANKS FOR THE HELP GUYS.
Elite Hatch
Dec 19, 2002 06:18 PM
