Diffrences between b16 and c5 transmissions?
Old Apr 3, 2005 | 03:54 PM
01-0720's Avatar
Default Diffrences between b16 and c5 transmissions?
i tried searching, i searched under diffrences between a b16 and b18 transmissions, i searched under b16 and b18 all kinds of stuff
so i was hoping someone could point out the differences between say a itr trans and a 99 up si b16 trans
as far as i know its the lsd and i think 5 gear but im not sure
thanks alot
eric
Old Apr 3, 2005 | 05:16 PM
1999all_motoR_teg's Avatar
Default Re: Diffrences between b16 and c5 transmissions? (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">i tried searching, i searched under diffrences between a b16 and b18 transmissions, i searched under b16 and b18 all kinds of stuff
thanks alot
eric</TD></TR></TABLE>
Well they are both 5 speed if that's what you meant by that.
for B18C5 and B16A2 transmissions the only difference is the B18C5 has LSD. The gear ratios and final drive are the same.
96-97 JDM ITR transmissions are the same as above. Only the 98+ JDM ITR transmission is different with a 4.785 final drive.
Old Apr 3, 2005 | 07:02 PM
Chubz's Avatar
Default Re: Diffrences between b16 and c5 transmissions? (1999all_motoR_teg)
98 abd above jdm itr tannys also have a taller 4th and ffth gear
Old Apr 3, 2005 | 07:33 PM
92TypeR's Avatar
FSAE
Default Re: Diffrences between b16 and c5 transmissions? (Chubzilla)
Older B16 trannys had smaller differential housings (ie: you could not fit an ITR LSD into a B16A1 tranny w/o modification), but around 95 or 96 (someone will know the exact year) the differential housings were changed to that of a B18 sized housing. Could have happened when the civics went from SiR-1 to SiR-2.
Other than that, the rest of the facts have been said already.
Old Apr 3, 2005 | 08:06 PM
chad's Avatar
Moderator
LSD only difference
Old Apr 3, 2005 | 09:01 PM
01-0720's Avatar
Default Re: Diffrences between b16 and c5 transmissions? (chad)
thanks guys
Old Apr 3, 2005 | 10:18 PM
GUILOTINE's Avatar
Kill Gil
don't ITR trannys have double or carbon Syncros?
Old Apr 3, 2005 | 10:23 PM
01-0720's Avatar
Default Re: (GUILOTINE)
no they dont
Old Apr 4, 2005 | 02:31 AM
DutchITR1689's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">don't ITR trannys have double or carbon Syncros?</TD></TR></TABLE>
No carbon, just double cone (only second gear)
http://www.imagestation.com/pi...g.jpg
Modified by DutchITR1689 at 8:31 PM 4/4/2005
Old Apr 4, 2005 | 09:30 AM
IVI's Avatar
IVI
Default Re: (DutchITR1689)
sorry to jack,
but are the clutches and flywheels interchangeable on those 2 trannies?
Old Apr 4, 2005 | 10:22 AM
chad's Avatar
Moderator
Default Re: (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">sorry to jack,
but are the clutches and flywheels interchangeable on those 2 trannies?</TD></TR></TABLE>
YES.....they are interchangeable....itr fw alittle less in the mass....
Old Apr 4, 2005 | 10:23 AM
IVI's Avatar
IVI
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
thank you sir, is it safe to assume the same for the gsr trans?
Old Apr 4, 2005 | 09:35 PM
chad's Avatar
Moderator
Default Re: (IVI)
yes....
b18b
b18c1
b18c
b18c5
b16a
b16b
b20b
b20z
all can use the same clutch flywheel
b18a tranny depends on the number of splines on the inputshaft
Old Apr 5, 2005 | 06:03 AM
JamaicanDM's Avatar
Default Re: (chad)
all are interchangeable except the 90-91 tranny's cuz the have different spline counts
Old Apr 5, 2005 | 06:24 AM
chad's Avatar
Moderator
Default Re: (JamaicanDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamaicanDM &raquo;</TD></TR><TR><TD CLASS="quote">all are interchangeable except the 90-91 tranny's cuz the have different spline counts</TD></TR></TABLE>
First GEN JDM B16a trannies YOU MUST COUNT SPLINES!!
they mix'd and match'd that tranny!!!
Old Apr 5, 2005 | 11:31 AM
X2BOARD's Avatar
Don't forget, some B16 trannies in the 92-95 SiR's came with an LSD as an option.
1320london
Feb 15, 2014 03:52 PM
00-501itrspec
Oct 13, 2005 03:13 PM
Sassafrass
Dec 1, 2003 10:06 AM
crazy eyez killa
Nov 24, 2003 09:01 AM
powerslide360
Mar 16, 2003 11:27 PM
