Difference between ITR and B16 tranny's?
I was having a discussion with a friend of mine about the difference in an ITR tranny and B16. I'm gonna keep things simple (or else I'll loose my train of thought) He says the only difference between the 2 tranny's is that the ITR has a better final drive and LSD. Obviously that is true but he also said the gearing is the exact same for both, is this true?
Risky Business
Re: Difference between ITR and B16 tranny's? (Sassafrass)
Actually the two trannies are nearly identical with the exception of the LSD. The B16 I believe has a slightly better 4th gear. See for yourself:
http://www.ff-squad.com/Bgears.htm
Re: Difference between ITR and B16 tranny's? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Actually the two trannies are nearly identical with the exception of the LSD. The B16 I believe has a slightly better 4th gear. See for yourself:
http://www.ff-squad.com/Bgears.htm</TD></TR></TABLE>
Depends on the year.
Moderator
Re: Difference between ITR and B16 tranny's? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Also, the FD depends on years. </TD></TR></TABLE>
yes
pre 98 itr had 4.4 98 and newer itr had 4.785
yes
