Proper Proportioning Valve
Old Apr 3, 2005 | 03:14 PM
oxSLEEPERxo's Avatar
Default Proper Proportioning Valve
it's a 92 cx( no abs) and my rear disc came off of a integra, i just need to know whats the proper car to take the proportioning valve off of. thanks
Old Apr 4, 2005 | 10:44 AM
Relic1's Avatar
Default Re: Proper Proportioning Valve (oxSLEEPERxo)
3030 - 9.5" front / drum rear
3035 - 9.5" front / larger drum rear
3040 - 9.5 front / disc rear
4040 - 10.25" front / disc rear
4035 - 10.25" front / larger drum rear
(there is also a 3540 that I've seen but I don't know what front brakes it had)
a 3040 would be best for you right now, unless you plan to upgrade your front brakes also, then go for the 4040.
4040 should be from pretty much any 94+ teg with rear disks.
3040 may be from an EX auto (EG or EK) without ABS. but I'm not sure.
Old Apr 4, 2005 | 11:55 AM
D21X's Avatar
Default Re: Proper Proportioning Valve (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">3030 - 9.5" front / drum rear
Crap, i just installed a 4040 on my 92 CX with 9.5" front rotors and rear drums. I do plan to get rear disc tho. think i'll be ok???
Old Apr 4, 2005 | 11:56 AM
kaiba's Avatar
Also 1725 from del sol b16a3 works too.
Old Apr 4, 2005 | 01:06 PM
clint g's Avatar
Default Re: Proper Proportioning Valve (kaiba)
the one from the 99-00 si work 2
Old Apr 4, 2005 | 01:10 PM
SOHC4life 96's Avatar
Default Re: Proper Proportioning Valve (clint g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g &raquo;</TD></TR><TR><TD CLASS="quote">the one from the 99-00 si work 2</TD></TR></TABLE>
Yes it will but he will have to bend his lines. If he gets one from the 5th gen Si it will be fine, or a teg RS. They all have the same prop valve as his car but the proportioning is different. The 99-00 Si is what you should use for the 6th gen civics.
Old Apr 4, 2005 | 03:43 PM
what proportion valve is in my car, and what car the valve i need is in?
Old Apr 4, 2005 | 03:44 PM
litterbox's Avatar
I am a (Trial User) Army
</TD></TR></TABLE>OMG I don't imagine how that would work. It could, I guess, but that would be the worst install EVAR!
Get a 4040 from any RS non abs teg.
Old Apr 4, 2005 | 03:54 PM
sohcvtec1995's Avatar
Default Re: Proper Proportioning Valve (litterbox)
if you can find a ex coupe one then that will work as well. I did a rear disc upgrade on my ex coupe and i used my stock PPV. works fine.
Old Apr 7, 2005 | 01:29 AM
BrokenHatch's Avatar
jdm y0
Default Re: Proper Proportioning Valve (sohcvtec1995)
anybody else have any ideas? i need to know also
Old Apr 7, 2005 | 03:45 AM
sic my duc's Avatar
i have a 92eg si nonabs, 9.5 fronts/ rear disc, and it came with 3040, put a 4040 with gsr fronts, yup got a 4040 off a rs non abs94up, ne one need my old 3040, or 1725, from del sol dohc
Old Apr 7, 2005 | 02:41 PM
jdm y0
Default Re: Proper Proportioning Valve (sic my duc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sic my duc &raquo;</TD></TR><TR><TD CLASS="quote"> ne one need my old 3040</TD></TR></TABLE>
hey man i really could use it, how much?
Old Apr 7, 2005 | 02:43 PM
litterbox's Avatar
Default Re: Proper Proportioning Valve (BrokenHatch)
I've got a 3040 and i'm in va. aim eh2andy
Old Apr 8, 2005 | 11:09 AM
sic my duc's Avatar
you should have a 3030, you can check on the firewall, you would need a 3040 off a 92-95 civic si non abs,and a del sol si, without b16 and abs should work too. thats only if you have 9.5 fronts,
Old Apr 8, 2005 | 11:12 AM
sic my duc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">what proportion valve is in my car, and what car the valve i need is in?</TD></TR></TABLE>
thats my reply to sleeper, still gettin used to this,
Old Apr 8, 2005 | 02:22 PM
Do_Ster's Avatar
couldn't you just use a MC from a 91 ex sedan (4 wheel discs) and be done with it? someone correct me if i'm wrong.
Old Apr 8, 2005 | 07:40 PM
sic my duc's Avatar
Default Re: (_OEM_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _OEM_ &raquo;</TD></TR><TR><TD CLASS="quote">couldn't you just use a MC from a 91 ex sedan (4 wheel discs) and be done with it? someone correct me if i'm wrong. </TD></TR></TABLE>
you still would have to upgrade the prop.valve to give the right pressure to the rear disc upgrade.
littleblue
Aug 24, 2009 12:20 PM
BlueTeg
Aug 29, 2005 09:01 AM
BlueTeg
11
Aug 25, 2005 10:43 PM
spoolinq
10
Jul 28, 2005 08:54 PM
