Accord revving problem
Old Apr 3, 2005 | 02:31 PM
Iceycrx's Avatar
Default Accord revving problem
A friend of mine has a 94ish sohc accord and has this problem and I wasn't sure what it could be off hand. At around 5-6k it will act as if it has a rev limiter. He said he switched ecus with another stock one and it still had this problem....he also has a msd blaster cap and external coil if that helps....
Old Apr 3, 2005 | 02:58 PM
YeuEmMaiMai's Avatar
check fuel filter, check intake and make sure it is not restricted, clean egr passage (requires fuel rail removial) check to see what fis fuel pressure is cause if it is low, you may need to replace the pump
Old Apr 3, 2005 | 04:06 PM
Iceycrx's Avatar
Default Re: (YeuEmMaiMai)
He has a B&M and has it set to like 40 and the gauge showed it there when the car was on. It isnt a bog he said it is like it hits the rev limiter
Old Apr 3, 2005 | 04:28 PM
maybe his tachometer is off.
Old Apr 3, 2005 | 05:20 PM
Iceycrx's Avatar
Hmm didn't think to ask that, what would cause the tach to read wrong...I am sure he would have mentioned if the tach needle didnt move correctly...
95blackEG
Dec 25, 2008 07:03 AM
civic-one
Dec 12, 2008 02:41 PM
dang_erous
Nov 12, 2007 07:44 PM
chiefvtec
Mar 3, 2003 04:23 AM
PM-Performance
Aug 19, 2002 03:40 AM
