Speedometer problems.
Old Apr 3, 2005 | 09:02 AM
07's Avatar
07
Default Speedometer problems.
Driving sometimes my Speedometer just drops outs, sometimes will come back, sometimes not. If it goes out for awhile it will throw a VSS code. Will it throw a VSS code IF the Speedometer head in the cluster is bad?
Old Apr 3, 2005 | 09:41 AM
BatuKing's Avatar
Default Re: Speedometer problems. (07)
No the code is given because the VSS sends out 2 signals one to your cluster and one to the ECU, so if its not working they both go out, my $$$ is on your VSS sensor
Old Apr 3, 2005 | 09:42 AM
civicboisi's Avatar
if it throws a VSS code then its the sensor in the tranny that's bad...the cluster should be fine but it COULD be the culperate too...but since it is throwing a code, i'd replace the VSS first before the cluster
Old Apr 3, 2005 | 11:11 AM
nota-ex's Avatar
Default Re: Speedometer problems. (civicboisi)
What if the speedo doesn't work, but the car isn't throwing a cel?
Old Apr 3, 2005 | 11:58 AM
07's Avatar
07
Default Re: Speedometer problems. (nota-ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-ex &raquo;</TD></TR><TR><TD CLASS="quote">What if the speedo doesn't work, but the car isn't throwing a cel?</TD></TR></TABLE>
I would say that would mean the acutally speedometer head in the guage cluster is broken.
Old Apr 3, 2005 | 12:30 PM
nota-ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07 &raquo;</TD></TR><TR><TD CLASS="quote">I would say that would mean the acutally speedometer head in the guage cluster is broken.</TD></TR></TABLE>
Alright. Because it works every once in awhile, I wasn't sure if the sensor, wires from sensor to ecu/cluster were bad, or if it was actually my cluster.
Old Apr 3, 2005 | 12:40 PM
BaYaReAJDMjunkie's Avatar
Buy a tach and save money
Old Apr 3, 2005 | 01:25 PM
nota-ex's Avatar
Default Re: Speedometer problems. (BaYaReAJDMjunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaYaReAJDMjunkie &raquo;</TD></TR><TR><TD CLASS="quote">Buy a tach and save money</TD></TR></TABLE>
tach shows rpm, not speed. And it sucks trying to guess how fast you are going based off of your rpm
Old Apr 3, 2005 | 01:31 PM
Do_Ster's Avatar
unfortunately, eg's are notorious for having this issue. i recommend swapping out the vss from a friend and if that doesn fix it, a quick way to determine if you need a new cluster is to take it out and push the needle. if there is not resistence like the tach, then you need a new cluster. i've been going 100mph for a couple of months now in 2nd gear haha stupid speedo
if the speedo has resistance start checking wires, fuses etc. hope that helps
Old Apr 4, 2005 | 09:57 AM
trigga's Avatar
Default Re: (_OEM_)
i had this in my 95 civic, i checked out my VSS its was fine so i replaced my cluster and it worked fine, i got a cluster with tach and white face's on it already at my house, dont need it any more $85 bucks takes it
Old Apr 4, 2005 | 10:02 AM
Shaun's Avatar
the wires from the harness that plug into the top of your VSS is loose or corrided , unplug the harness to the sensor and make sure none of the above things are happing
beatngyou27
26
Nov 8, 2013 06:59 AM
Love-MY-honda
14
Dec 23, 2010 07:36 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
sireg6
Sep 26, 2006 01:38 PM
hb_guy
13
May 25, 2006 08:23 PM
