what kind of cams will have good ilde and power?
Old Apr 2, 2005 | 10:55 PM
itr1244's Avatar
Default what kind of cams will have good ilde and power?
i was shopping around for cams but it's too hard to choose one
i was looking at blox, skunk2 pro1, buddy club.
which one would have good idle and still makes good power?
i just read the skunk2 pro1 makes good power but looks like everyone seems to have bad ilde...
please give me some inputs
thanks alot
Old Apr 2, 2005 | 11:23 PM
Mike K's Avatar
Default Re: what kind of cams will have good ilde and power? (itr1244)
when it comes to cams, you'll see everyone has their own opinion.
my opinion is Toda Spec A. without a doubt, my favorite cam.
stock idle and driveability. similar to ITR cams in their powerband, but a little more power up top. best way to describe them is like ITR cams with 5-7hp more tuned vs. tuned.
but i plan on trying the Blox Spec A when i install my motor one of these days.
Old Apr 2, 2005 | 11:27 PM
itralex's Avatar
Default Re: what kind of cams will have good ilde and power? (Mike K)
Toda B's
Old Apr 3, 2005 | 11:10 AM
itr1244's Avatar
Default Re: what kind of cams will have good ilde and power? (itralex)
hey.. i know you guys dont care but please? can you give me some inputs?
Old Apr 3, 2005 | 11:27 AM
RTW DC2R's Avatar
my 2 cents. I ran JUN3's, made around 205whp, idled like stock. I would imagine you can tune most cams on our cars to idle like stock as long as you have something like a standalone set up.
Old Apr 3, 2005 | 12:22 PM
Flux's Avatar
Default Re: (RTW)
If you want a reliable, quality cam that makes power without even knowing it is there the TODA spec As are the answer in my opinion...
Old Apr 3, 2005 | 12:36 PM
MooFX's Avatar
Good idle? what do you mean by good idle though? beefy / lobey idle? or a smooth idle?
I'd pick toda b's for a beefy idle, and JUN 3's for a smooth / stock like idle. They both made very decent numbers when I had them in my car.
-Justin
Old Apr 3, 2005 | 03:25 PM
B2FiNiTY's Avatar
Default Re: what kind of cams will have good ilde and power? (MooFX)
Depends on what you are looking for and where the power is to be made.
Spoon, Toda A, JUN III all idle very well.
Old Apr 3, 2005 | 03:45 PM
TOP END MS's Avatar
Skunk2 stage 1-2, Buddy Club stage 1-2, TODA ..
id prob. also look into what other head work you want and decide from there.. ex: if your thinking of Skunk2 valve springs and retainers .. then i say get Skunk2 cam .. if you want Buddy Club head work .. go with Buddy Club cam .. I like to do things in packages from one company.. this way you know it was all tuned together for best results.
Old Apr 3, 2005 | 07:01 PM
itr1244's Avatar
Default Re: (TOP END MS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 stage 1-2, Buddy Club stage 1-2, TODA ..
id prob. also look into what other head work you want and decide from there.. ex: if your thinking of Skunk2 valve springs and retainers .. then i say get Skunk2 cam .. if you want Buddy Club head work .. go with Buddy Club cam .. I like to do things in packages from one company.. this way you know it was all tuned together for best results. </TD></TR></TABLE>
okay. that makes sense ..
but those toda/jun cams sounds good but they arekind of out of my price range.
i'm one broke ***
so i was looking at some skunk 2 pro1 cams + gear for not bad price.. but those cam lubes on these cams are supposed to be pretty big.
so i need high compression to run aftermarket cams?
would it pass using aftermarket cams with thin head gaskets. and stock bottom end?
Old Apr 3, 2005 | 07:37 PM
92TypeR's Avatar
FSAE
Default Re: (itr1244)
If the JUN3's are too pricey, the Skunk2 Stage 2's have similar profiles on both the primaries and VTEC lobe.
pimpinblackcivic
26
May 20, 2007 01:35 PM
IntegraLs94Cam
25
Jul 5, 2006 12:08 PM
skeeterDX
Dec 24, 2004 05:03 PM
Short_Shifter
Feb 6, 2002 01:30 PM
GSRacer
Oct 3, 2001 11:22 AM
