where can i find this OBD0 to OBD1 Distrbutor Adapter
OBD0 to OBD1 Distributor Adapter. Makes the OBD0-1 conversion easier by allowing you to just plug in the OBD1 distributor to your OBD0 wiring harness! No cutting required! Requires the use of an OBD1 distributor and OBD1 ecu (obviously!). NOTE: THIS DISTRIBUTOR ADAPTER IS DESIGNED TO ONLY WORK WITH OUR OBD0-1 ECU ADAPTER. IT WILL NOT WORK PROPERLY WITH ANY OTHER ECU ADAPTER, AS IT IS WIRED SENSOR TO SENSOR, NOT COLOR FOR COLOR! Please be sure to check your ecu adapter instructions if you are ordering this to work with another manufacturers ecu adapter!
i need this guy, you know where i can find this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whizdumb »</TD></TR><TR><TD CLASS="quote">http://www.rywire.com/021dizzy.shtml
but it's pretty easy to re-pin the dizzy, saves you $25</TD></TR></TABLE>
thanks for the reply and yea i can order online but i wanna know if i can pick up one near by?
ryanangelo212
Mar 18, 2013 12:23 AM
