just installed a turbonetic turbo kit and now the car overheats HELP!!!
Old Apr 2, 2005 | 04:35 PM
jeffchaisi's Avatar
Default just installed a turbonetic turbo kit and now the car overheats HELP!!!
like the title sayed. i just installed a turbometic turbo kit on my EG with b18c gsr swap every thing went smooth and i have a fluidine alminum radiator before the turbo install. here's the story i have fluidine radiator with stock fan no overheat problems at all and after the turbo install i have the fluidine radiator with a front mount push perma-cool 12" radiator fan and now if i am stuck in traffic my temp start to go up little by little till it reach close to the red spot and before it reach i turn the car off. and i am 100% sure my front mount fan is working properly. does this happen to any one else need help!
Old Apr 2, 2005 | 07:20 PM
Finland's Avatar
Maybe you need to bleed your cooling system, it might have an air pocket in it.
Old Apr 2, 2005 | 08:10 PM
trentepic's Avatar
Default Re: (Boondock Saint)
with overheating problems its important to know if it does it crusiing on the highway etc.
btw id check to see if the fan is pulling the air the right way, if its wired to suck air out of engine bay throught the fron of the car, when u drive on the road and cruise the fan and the natural airflow will fight and ur temperature will rise really fast and never go down till u park.
-Toby
Old Apr 2, 2005 | 08:22 PM
BlueShadow's Avatar
Default Re: just installed a turbonetic turbo kit and now the car overheats HELP!!! (jeffchaisi)
are you going off of your stock temp gauge? do you have an aftermarket temp gauge hooked up? also are your fans wired up like stock, or do you have it hooked up to a switch so you can turn it off and on when you want? You might wanna think about running a switch or something so that you can turn your fan on when you want. Or maybe you can set it up so your fan are always on.
Before you do burp your coolant system and get rid of any air pockets in the system.
shadow103rd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you need to bleed your cooling system, it might have an air pocket in it.</TD></TR></TABLE>
Beat me to it!
Old Apr 3, 2005 | 10:10 PM
jeffchaisi's Avatar
i dont think i have air pockets in the system. the front mount fan is set up to stock fan wiring. i works when the engine reach the temp.
Old Apr 3, 2005 | 10:50 PM
SHystrdyGSRtdy's Avatar
Default Re: (jeffchaisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffchaisi &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i have air pockets in the system. the front mount fan is set up to stock fan wiring. i works when the engine reach the temp. </TD></TR></TABLE>
isn't stock fan wiring setup to pull? that's how my stock gsr is.. i mean the fan is INSIDE the engine bay PULLING air...
Old Apr 3, 2005 | 11:03 PM
PrettyLude's Avatar
Default Re: (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">isn't stock fan wiring setup to pull? that's how my stock gsr is.. i mean the fan is INSIDE the engine bay PULLING air... </TD></TR></TABLE>
yeah you right, switch the wiring around
Old Apr 3, 2005 | 11:08 PM
jeffchaisi's Avatar
the radiator fan right now is mounted in the front of the radiator and it's set to push air in to the engine bay
Old Apr 4, 2005 | 12:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffchaisi &raquo;</TD></TR><TR><TD CLASS="quote">the radiator fan right now is mounted in the front of the radiator and it's set to push air in to the engine bay</TD></TR></TABLE>
are you saying your wiring is correct? can you please elaborate a little more? earlier you said it was setup like the stock wiring (default is set to pull).
here it is from the flex-a-lite website (though you may not have a FAL fan, but the concept is the same):
Wiring Instructions
Important: Puller fans use:
Blue/Red wire is positive (+).
Black wire is negative (-).
Important: Pusher fans use:
Black wire is positive (+).
Blue/Red wire is negative(-).
Reverse wiring
when installing
#396, 16” S-Blade
Reverse wiring
when installing
#396, 16” S-Blade
hope that helps
Old Apr 4, 2005 | 12:17 PM
dustin's Avatar
Did you flip the blade? You usually have to reverse polarity + flip the blade
Old Apr 4, 2005 | 05:27 PM
jeffchaisi's Avatar
oh ok i did flip the blade to the push fan style and i also have to switch the wiring so i have to do both right?
Old Apr 4, 2005 | 06:45 PM
miro_gt's Avatar
dude, you really suck if you can't figure out how the fan is working ....
here is some help: the air comes from the front, passes through the radiator, and goes towards the engine bay ... when you stop, no air is passing, so no cooling is produced. Therefore you have a fan to make air movement in the same direction ... go and check what's going on
Old Apr 5, 2005 | 02:22 PM
jeffchaisi's Avatar
swith the wires and now it's perfect! thanks guys
Old Apr 5, 2005 | 02:23 PM
w00t.. you're welcome
Old Apr 5, 2005 | 02:30 PM
YiNYaNg's Avatar
I can see it...this guys next overheating problem will be a blown head gasket....
Slosc2
May 1, 2009 12:37 PM
totsie7944
Oct 9, 2008 12:23 PM
TommyV
Apr 13, 2003 12:13 PM
92JDMSiR
Jun 9, 2002 12:59 PM
