LS/Vtec 1st startup, wierd noise, pls help
Hey whats up everyone, i just completed my lsvtec build, put it in the car and started her up. No major problems except for an odd noise ive never heard before. It was a high pitched whistle/squeal. Almost like air rushing through a small openning, but not exactly. Not VERY loud, but u can definatley hear it well. I tracked it to the air filter, then removed the filter and intake tube, and started the car again and I heard it coming from throttle body, definatley from that area.
I did the normal vaccum leak checks, no hoses unpluged, nothing obvious. What could this noise be? The motor is an ls bottom end, gsr head, and I added a JG intake manifold with hondata gasket. The only thing i could think of is the throttle body gasket possibly, but i didnt have any more time to check things out. And the motor runs well, not like it had a vaccume leak.
Any ideas? thnx for anyones help on this one. If i can Ill get a vid clip later so you can hear the sound.
the problem was that the iac valve did not seal well on the edelbrock mani, it was not a big enough leak to be detected with intake cleaner but after sealing it with rtv sealen the noise has stopped
chestnut_55
May 13, 2005 10:51 AM
Mike17
May 8, 2004 06:06 AM
