Code trouble
Old Apr 2, 2005 | 10:16 AM
silver hatch's Avatar
Default Code trouble
I jsut swapped a zc into my 1991 hb. i started the car and the check engine light came on i checked codes and i got 7 and 20. the car is also idling between 2000 and 3000. i checked my grounds to solve code 20 but its still there. anyone have any suggestions of how to fix these?? its a pm7 ecu.
i searched and found this, but it was no help.
https://honda-tech.com/zerothread?id=1148683
Modified by silver hatch at 12:33 PM 4/2/2005
Old Apr 2, 2005 | 10:29 AM
D-Atk's Avatar
Default Re: Code trouble (silver hatch)
code 7 is your tps sensor
code 20 electrical load dector
here
https://honda-tech.com/zerothread?id=978933
Old Apr 2, 2005 | 10:53 AM
B SERIES US's Avatar
yup
Old Apr 2, 2005 | 11:32 AM
Default Re: Code trouble (D-Atk)
so how do i fix them?
Old Apr 2, 2005 | 12:50 PM
i got the idling down to ~1200, it was a vacuum line prob.
but i still have code 20 and 7. i know that they are elc and tps.
i also changed the wires on the tps plug back to the dx way(Y/R/G) (i changed it to G/R/Y when i did the swap, like you are suppose to)just to see what would happen but this had no effect on the car. should this affect anything?
how do i check the tps without replacing it?
Old Apr 2, 2005 | 12:56 PM
red_crx's Avatar
what ecu are you using?
Old Apr 2, 2005 | 01:05 PM
Default Re: Code trouble (red_crx)
pm7
Old Apr 2, 2005 | 01:23 PM
D-Atk's Avatar
Try resetting the ecu
Old Apr 2, 2005 | 01:38 PM
tried it
BlueRex1020
Dec 4, 2025 01:21 AM
Mr.Death
Apr 30, 2010 05:51 PM
vtc-gn2
Mar 29, 2005 07:01 PM
drunk
Oct 20, 2002 03:29 PM
l
Mar 24, 2002 07:47 PM
