GSR Crank w/ LS rods and pistons
ok well i am starting to buy the stuff for my build. what i want is a B18B1 block with a GSR crank and Eagle LS Rods and 82mm Weisco pistons. the reason i want the gsr crank is to rev a lil higher as i am going to run a fully built jdm itr head and it will be boosted. Will this work? Thanks for any insight u can provide.
y are u using LS rods. since the ls rods are a little bit shorter cause they use the 89mm stroke.
you need to grab some GSR or Type R rods to maintain a good RS ratio. if you use the LS rods the piston wont make it to the deck of the block.
ok thanks, i was gonna use ls rods cause my best friend has a set of eagle ls rods i could score pretty cheap. but i guess ill just buy a new set. thanks again
Mfoehrkolb
Nov 21, 2007 05:37 PM
