With Uberdata, can a Stock Honda MAP Sensor Read Boost?
Old Apr 2, 2005 | 07:36 AM
B16Civic93's Avatar
Default With Uberdata, can a Stock Honda MAP Sensor Read Boost?
like it says can a stock honda MAP sensor read boost with uberdata? if so how much? do i need to use a missing link or am i ok without one?
Old Apr 2, 2005 | 07:37 AM
non-VTEC's Avatar
Default Re: With Uberdata, can a Stock Honda MAP Sensor Read Boost? (B16Civic93)
the stock map sensor is good up to around 11-12psi.......
Old Apr 2, 2005 | 07:47 AM
redline300z's Avatar
no missing link, and yes, 11-12 psi, but you can go higher if you richen up the last columns i guess
Old Apr 2, 2005 | 09:20 AM
nonvtecD's Avatar
After .75 bar of boost (stock map sensor rating) the map sensor will still read fuel and timing values for .75 bar, so if it is rich enough you can run more boost while staying safe.
Old Apr 2, 2005 | 09:39 AM
HiProfile's Avatar
Default Re: (nonvtecD)
Like nvD said, richen up the last column and it will use that map for anything over 11.73psi
To answer the next question you might have, yes a 3bar GM map sensor will work and read up to 24-28 psi, but it idles like crap because of the sensor's vacuum readings. They're working on it, and hopefully will have it fixed soon.
krugozor
Feb 21, 2011 08:38 PM
hatchBK4life
Feb 3, 2010 12:08 PM
Mr. Softee
Mar 25, 2003 07:29 PM
DIRep972
Mar 11, 2002 07:01 PM
whagkangmakulet
Dec 18, 2001 11:06 PM
