Lifting car for bigger tires/rims? SRS light trouble?
Old Apr 1, 2005 | 09:07 PM
DefendentOfHate's Avatar
Default Lifting car for bigger tires? SRS light trouble? Bouncing RPM?
i have a 96 accord ex v6, and i currently have 15s on it... to get bigger tires on it, say 19s will i have to lift it? if so what products do u recommend peeps ta do so? and my SRS lite has been on. been on since i got it. tha guy said he checked it out n nothin was wrong wit it. how do i turn it off? and occasionally my RPM tach needle will bounce around, the car doesnt putt around tho when it does it. what is it and how do i fix it?? help me imma newbie can someone also help me wit info on increasing my hp and making my car faster??? and DIY sites, im tryin ta learn da mechanics. ty in advance
Old Apr 1, 2005 | 09:23 PM
brads94accord's Avatar
you can fit 19's on a 5th gen without a lift. you can actually still fit them with a drop..they just need to be the right offset and no more than 7.5 inches wide. as far as the SRS light im not sure about that, the systems have been know to mess up over time on 5th gens. Now the part about making your car faster, theres not too many aftermarket parts for the v6 models...and you definately wanna remove the 19's from your list of mods cause that will make you slower.
Old Apr 2, 2005 | 06:25 AM
Default Re: (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote"> you definately wanna remove the 19's from your list of mods cause that will make you slower.</TD></TR></TABLE>
and uglier.
Old Apr 4, 2005 | 02:47 PM
so keep tha 15s on my car? What about my RPM tach?
Old Apr 4, 2005 | 03:06 PM
rainforest's Avatar
Default Re: (DefendentOfHate)
the srs light is probablly a seat belt latch they usually go bad.
Old Apr 4, 2005 | 10:46 PM
so check tha seat belts maybe? could it be anyone of them, or does anyone know how to get tha light to go off... still what about the tachometer and my needle bouncing, how to fix that??
Old Apr 4, 2005 | 11:44 PM
SpeedFreak77's Avatar
If I were you I wouldn't go any bigger than an 18, which you can lower your car still and close up that gap and it will look really clean. As far as your SRS light you need to have your air bags checked it's something to do with that.
Old Apr 5, 2005 | 10:06 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (SpeedFreak77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">As far as your SRS light you need to have your air bags checked it's something to do with that.</TD></TR></TABLE>
It's not necessarily the airbags themselves. As someone stated, it could be associated with the seatbelts, the control module, an unplugged wire at the wrong time causing an error, or maybe a blown fuse. The light is on for a reason. If the problem that caused the light to come on has been fixed then you need to reset the system. Directions on how to reset the system can be found on this site with a simple search for "SRS Reset" or by also going into the "Guide to basic Accords" thread. But if the problem hasn't been fixed yet then you need to fix it then reset the system. If you just try to reset the system without fixing the problem the light will just come back on.
Old Apr 5, 2005 | 08:37 PM
Default Re: (TouringAccord)
I know it could be a seat belt but that whole system is tied together and should be checked by a shop.
fivestarpacheco
Jul 1, 2022 01:35 PM
mdh061
31
Apr 14, 2016 07:45 AM
BudgetFitting
Honda Fit
11
Oct 3, 2008 11:21 AM
rltrock
Jan 21, 2003 12:27 PM
mistergin
Sep 12, 2002 04:33 PM
