20 mile itch.
Old Apr 1, 2005 | 08:19 PM
mugenhatchie's Avatar
Default 20 mile itch.
Hey sorry but just another question for my friend. He has a civic ex with a b16A SIR II motor obd2 motor. he has the right ecu and everything looks wired righ but when he drives about 20 miles the motor spazzes out. the RPM and SPEEDO gauges start to twitch and jump along with the motor. then the motor just bogs out when you try to accelerate. what the hell is up with this. I was thinking it may be related to his ecu running closed loop/open loop and one of his sensors being bad. i am probably totaly wrong so i need your help. our local shop cant figure it out at all. He is running a VAFC and stock ecu. Any enlightenment would be great. he cant really afford to spend anymore mone fixing problems that mechanics around here "think" are worng. Thanks again guys.
Old Apr 1, 2005 | 08:25 PM
civiccpedx's Avatar
Default Re: 20 mile itch. (4door14's)
maybe the grounds are bad?
Old Apr 1, 2005 | 08:28 PM
Grounds???? to the sensors?? or the motor grounds?? thanks for bearing with me
Old Apr 1, 2005 | 08:29 PM
THugluv423's Avatar
motor
Old Apr 1, 2005 | 08:30 PM
_Cyclone_'s Avatar
Has the ECU gotten wet recently? The same thing happened to my friend's integra when the ECU got wet from a big water leak.
Old Apr 1, 2005 | 08:32 PM
no its brand new and has never seen any moisture.
Old Apr 1, 2005 | 08:45 PM
spyderracing's Avatar
Did it have the problem pre-VAFC?
Old Apr 1, 2005 | 09:17 PM
Default Re: 20 mile itch. (spyderracing32)
yes
Old Apr 1, 2005 | 09:37 PM
_Cyclone_'s Avatar
um, ok... why whould he install a VAFC while there is a serious problem like that?
Old Apr 1, 2005 | 09:38 PM
DohcSide's Avatar
Default Re: 20 mile itch. (CycloneBlue_1.6EL)
check your pressure siglnal the pink wire i think or just pull out the negative from teh battery to reset everything
willb83
Jul 3, 2012 10:52 PM
919DumpedCD5
Dec 22, 2010 07:05 PM
Killersohc
Oct 15, 2010 11:48 AM
Projct_hatch90
Mar 24, 2006 05:13 AM
