oil check light/braking
hey everyone!
Just another question. On my b18c1 i am having problems with my oil check light. When i am driving and get to cruising and then go to brake for a stop light or something wher i have to apply moderate braking my oil check light flashes on for a second then goes out. i though my oil might be low but i checked it and its fine. I am stumped and cannot figure this out. i just hope its not serious and to prevent any damage i stopped driving it for now. what could it be??? any help would be great. thanks again guys!!!!
Thanks. what sould i do about it. i am lost. also why would it only occur after the rpms come down or during braking.
is the oil pump bad???
i couldn't tell you how to fix it, and mine does the same thing when I get low on oil, if I brake really hard, oil light will flicker and then go off, but I check my oil religiously, just a few times have a i let it get low, im sure someone else can help you more than I can
That's really weird. That light comes on when oil pressure is under 7 or 5psi (one or the other). That is dangerously low pressure. I idle at 25lb and top rev around 75psi. Could be the oil pump going bad, clogged filter or a bad oil pressure sensor.
Sorry to dig up an old thread but I have the same problem on my LS, any cures?!
My oil level is fine but when I brake or deccelerate the oil light flickers on.
HELP!!!11
HELP!!!11
MUGEN_EG95
10
Oct 25, 2007 07:24 AM
1 Cam Wonder
44
Nov 23, 2004 08:18 AM
