How do you calculate compression ratios?
Old Apr 1, 2005 | 06:44 PM
typeeg's Avatar
Default How do you calculate compression ratios?
Ok I tried a search but came up with a lot of stuff but not specific to my question on compression ratio.
I often see compression ratios of 11:1 or 12:9:1 and what not.
I believe to come up with these figures you divide the cubic volume within a cylinder of the motor at TDC by the volume at BDC.
So for instance if you get 100cc's at TDC and 20cc's at BDC then you have 10:2. I read this off some other thread on this site.
But my question is why do some ratios have a number in the middle like 12:9:1? What does the 9 mean?
Also I assume the higher the first number the more power the motor can produce, how are the other numbers fit into the equation as far as what is better or worse?
For instance would 11:2:1 compression be better than 11:3:1 or vice versa?
Thanks for your insight.
Old Apr 1, 2005 | 07:05 PM
chameleon's Avatar
Default Re: How do you calculate compression ratios? (Reckless636)
it actually tells you the math equation for figuring this out in the CTR/PCT piston sticky post here in the all motor forum. or check out c-speedracing.com for the comp calculator, its not correct on ctr piston comp but everything else is close.
Old Apr 1, 2005 | 07:19 PM
5STAR3's Avatar
Default Re: How do you calculate compression ratios? (chameleon)
its actually 11.5:1 or 11.2: or 12.4:1 and so on. if you ever see 12:5:1 its just a typo.
makes sense? there is no 11:5:1
eleven point five to one, is how you would read it. NOT eleven to five to one.
hope that helps a little
Old Apr 2, 2005 | 10:34 AM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">it actually tells you the math equation for figuring this out in the CTR/PCT piston sticky post here in the all motor forum. or check out c-speedracing.com for the comp calculator, its not correct on ctr piston comp but everything else is close.</TD></TR></TABLE>
i find that http://www.zealautowerks.com is more accurate than the c-speed calculator
Old Apr 5, 2005 | 06:17 PM
typeeg's Avatar
Default Re: How do you calculate compression ratios? (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">its actually 11.5:1 or 11.2: or 12.4:1 and so on. if you ever see 12:5:1 its just a typo.
hope that helps a little</TD></TR></TABLE>
I'm still confused. What do you mean it's actually 11:5:1?
How is 11:5:1 different from 11:3:1? Or is that just another way to say 12:1? I'm so confused lol.
Old Apr 5, 2005 | 06:25 PM
Professor15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reckless636 &raquo;</TD></TR><TR><TD CLASS="quote">
How is 11:5:1 different from 11:3:1? Or is that just another way to say 12:1? I'm so confused lol.</TD></TR></TABLE> I believe he was talking about how people type 11:5:1 when they actually mean 11(.)5:1. They use ( instead of the point (.) which is the correct way of using it.
Old Apr 6, 2005 | 12:33 PM
typeeg's Avatar
Default Re: How do you calculate compression ratios? (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo &raquo;</TD></TR><TR><TD CLASS="quote"> I believe he was talking about how people type 11:5:1 when they actually mean 11(.)5:1. They use ( instead of the point (.) which is the correct way of using it.</TD></TR></TABLE>
Oh Ok that does make sense then. Thanks!
Old Apr 6, 2005 | 12:48 PM
5STAR3's Avatar
how is 11.5:1 different from 11.3:1?
well it is a ratio. so 11.5:1 is larger than 11.3:1
so in general, for every 1(one) of something you have 11.5 of something else. where as for every 1(one) of something you only have 11.3 of something else.(the second one is less). just look up the word ratio in reference to math, otherwise i dont know what to tell ya.
in the context we are using it it refers to compression/pressure.
hatch22ajdm
Engine Machining & Assembly
Jun 1, 2018 03:33 AM
TravisCadello
Feb 4, 2009 12:16 PM
flatblack-h22
Jul 16, 2007 01:23 PM
builtprelude
Jan 22, 2004 10:49 PM
HX_Guy
Dec 6, 2001 03:24 PM
