Fuel pump/ECU Relay?
I have a no start problem and it appears there is no power at ECU as i have no red light.I just recently had to rewire fuel pump as it was only getting 10-10-5 volts from the original wires off the harness so i ran 12 volts ign power to the pump fixing that problem.I suspect the relay that apperantly powers these two is bad or has a poor connection.Does anybody know where the fuel pump/ecu relay is located?
well i just ahd the same problem today and my tranny ground was loose so check it if the ecu isnt turning on but im still having the fuel pump problem
you are 100% correct, the pump and ecu get it from the main relay.
you can take it apart and re-solder the connections, OR you can just get a new one from the dealer. its actually 2 relays in one box.
krysted9354
20
Apr 8, 2009 03:32 PM
