just swapped out my b16 tranny for a gsr tranny... havin axle problems
Old Apr 1, 2005 | 05:20 PM
Aespooncivic's Avatar
Default just swapped out my b16 tranny for a gsr tranny... havin axle problems
i just swapped out my b16 tranny and swapped in a gsr tranny.I swapped them because 3rd gear in the b16 was shot and got the gsr for 400.00.. its on the motor... and the motors bolted up.. i popped the right side axle in and put tryed puttin the ball joint back in the hole and its an inch or two off... my question is will my b16 axles work for the gsr tranny..?
ill have pics up tonight
Modified by Aespooncivic at 6:35 PM 4/1/2005
Old Apr 1, 2005 | 05:31 PM
EG6 SiR's Avatar
Default Re: just swapped out my b16 tranny for a gsr tranny... havin axle problems (Aespooncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic &raquo;</TD></TR><TR><TD CLASS="quote">my question is will my b16 axles work for the gsr tranny..?
Yes, they are interchageable
Old Apr 1, 2005 | 05:34 PM
Default Re: just swapped out my b16 tranny for a gsr tranny... havin axle problems (EG6 SiR)
thanks.. can i ask a question.. why am i have the problem of not fittin then..
Old Apr 1, 2005 | 05:35 PM
any suggestions? eg6 sir
Old Apr 1, 2005 | 05:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions?</TD></TR></TABLE>
Old Apr 1, 2005 | 06:09 PM
red91sit's Avatar
hehe wrong thread, anyways ARe you srue all the joints are fully seated? check the CV joints for any joints that have crinkles in their boots. sometimes spinning the wheel will get them to pop back into place atleast it did on my b16.
Old Apr 1, 2005 | 06:26 PM
Default Re: just swapped out my b16 tranny for a gsr tranny... havin axle problems (red91sit)
how do i tell if there fully seated
Old Apr 1, 2005 | 07:07 PM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions? eg6 sir</TD></TR></TABLE>
what exactly is not going in? Is the axle already in the tranny and its not sliding into the hub?
Old Apr 1, 2005 | 07:26 PM
it seems to be in the tranny (right side)and i slid it though the control arm and the ball joint wont go in the hole on the bottom
Old Apr 1, 2005 | 08:30 PM
red91sit's Avatar
Well with mine i just pushed the top of the hub in and turned the axle and it popped back in. I'm not sure why, but teh cv joint was extra long and after I pushed it in it went back to normal length.
You mean the axle you have now seems like its' too long right? like the hub won't line up cuz you can't get enough camber out of it?
Old Apr 2, 2005 | 12:23 AM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic &raquo;</TD></TR><TR><TD CLASS="quote">it seems to be in the tranny (right side)and i slid it though the control arm and the ball joint wont go in the hole on the bottom</TD></TR></TABLE>
You need to make sure the axle is staight and push it in. The joints will extend if you pull on them, thus making it longer and not seating right.
Old Apr 2, 2005 | 10:01 PM
update: i feel really stupid...the axle was broken... i didnt take the axle out completely.. i popped it out and let it rest there while i dropped the tranny though the bottom.. the tranny must hit the axle... new axle tommarow..!
Old Apr 2, 2005 | 10:22 PM
1.8EG-T's Avatar
teamsoy1320
49
Jul 20, 2006 12:44 PM
smokerz212
Apr 25, 2006 02:04 AM
ll Del La Sol ll
Jun 10, 2005 11:37 AM
locoSIR20
Feb 1, 2005 05:53 PM
92-EG6
30
Mar 14, 2004 06:18 AM
