just swapped out my b16 tranny for a gsr tranny... havin axle problems
i just swapped out my b16 tranny and swapped in a gsr tranny.I swapped them because 3rd gear in the b16 was shot and got the gsr for 400.00.. its on the motor... and the motors bolted up.. i popped the right side axle in and put tryed puttin the ball joint back in the hole and its an inch or two off... my question is will my b16 axles work for the gsr tranny..?
ill have pics up tonight
Modified by Aespooncivic at 6:35 PM 4/1/2005
Re: just swapped out my b16 tranny for a gsr tranny... havin axle problems (Aespooncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">my question is will my b16 axles work for the gsr tranny..?
Yes, they are interchageable
Re: just swapped out my b16 tranny for a gsr tranny... havin axle problems (EG6 SiR)
thanks.. can i ask a question.. why am i have the problem of not fittin then..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">any suggestions?</TD></TR></TABLE>
hehe wrong thread, anyways ARe you srue all the joints are fully seated? check the CV joints for any joints that have crinkles in their boots. sometimes spinning the wheel will get them to pop back into place atleast it did on my b16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">any suggestions? eg6 sir</TD></TR></TABLE>
what exactly is not going in? Is the axle already in the tranny and its not sliding into the hub?
it seems to be in the tranny (right side)and i slid it though the control arm and the ball joint wont go in the hole on the bottom
Well with mine i just pushed the top of the hub in and turned the axle and it popped back in. I'm not sure why, but teh cv joint was extra long and after I pushed it in it went back to normal length.
You mean the axle you have now seems like its' too long right? like the hub won't line up cuz you can't get enough camber out of it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">it seems to be in the tranny (right side)and i slid it though the control arm and the ball joint wont go in the hole on the bottom</TD></TR></TABLE>
You need to make sure the axle is staight and push it in. The joints will extend if you pull on them, thus making it longer and not seating right.
update: i feel really stupid...the axle was broken... i didnt take the axle out completely.. i popped it out and let it rest there while i dropped the tranny though the bottom.. the tranny must hit the axle... new axle tommarow..!
smokerz212
04-25-2006 02:04 AM
