help me can't PASS Emission test
Old Apr 1, 2005 | 03:52 PM
90accordf22's Avatar
Default help me can't PASS Emission test
I have a 1990 accord 2-door with 109k miles on it, and i'm trying to pass emissions, but my engine is gay. how do i get low hydrocarbons and carbon Monoxide levels?
Old Apr 1, 2005 | 03:57 PM
THEFiJiMAN's Avatar
Default Re: help me can't PASS Emission test (90accordf22)
Your engine may be running too rich. I have emissions check in Ohio; I ran my car with some cleaner gas and that helped.
You can also ask for an idle test. The test sometimes misses in those.
Old Apr 2, 2005 | 05:24 AM
Obsidian's Avatar
Default Re: help me can't PASS Emission test (THEFiJiMAN)
clean your throttle body, get new air filter. Have them do the test after your car is already warmed up and run a fuel system cleaner.
Old Apr 2, 2005 | 10:40 AM
dirtracer's Avatar
Not only the tings above but also change your oil plugs posible wires & dis. cap. We do all these changes in Canada before E Test. Didn't change my wire's and it cost me $100.00 more for dino test only for me to tell them I never changed the wire's still charged for the dyno that could find nothing wrong
Old Apr 2, 2005 | 01:17 PM
TOP END MS's Avatar
Do they still have that rule where u can spend $500+ to fix and theyll consider it good enough? ..
Old Apr 2, 2005 | 05:04 PM
SuShiBoiiii's Avatar
Default Re: (TOP END MS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">Do they still have that rule where u can spend $500+ to fix and theyll consider it good enough? ..</TD></TR></TABLE> yes
Old Apr 2, 2005 | 05:48 PM
Robot Sonic's Avatar
****, in NJ they dont give 2 *****, they fail and keep on failing til they can re-test the car consistently and it passes.
Old Apr 3, 2005 | 02:34 PM
YeuEmMaiMai's Avatar
change oil plugs PCV valve air filter and maybe if you are feeling unlucky o2 sensor. my car is at 128K now and it passes emmission easliy
Old Apr 4, 2005 | 12:44 AM
RotaryBzzzz's Avatar
Default Re: (YeuEmMaiMai)
A 1990 accord w/ 109k miles...not passing on HC and CO...
Did you inherit this car from a grandparent?
Old Apr 4, 2005 | 02:03 AM
CB7VTEC's Avatar
Default Re: (RotaryBzzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">Did you inherit this car from a grandparent? </TD></TR></TABLE>
no kidding, that car should be running pretty damn clean...
lilazndrag0n02
Jun 8, 2008 01:03 AM
mark_is_gay
May 10, 2006 07:49 AM
NightRiderS2K
Jan 1, 2005 09:20 PM
88LXiProject
Oct 2, 2003 10:40 AM
nek0
Jun 23, 2003 08:54 AM
