removing shift forks (d16)
Was tooling around under the car last night and i couldnt figure out how to get the shift forks off. I looked in my helms and that didnt help any either.
I searched and found this thread but thats not helping me.
https://honda-tech.com/zerothread?id=853950
You have to get the tranny out of the car first. The tranny has two halves which must be split apart in order to get to the shift forks.
Are you talking about how to get shift linkage un-done - the rolled-spring pin? You just need a 8mm non-tapered punch and a 10lb mini-sledge to get that bitch out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">You have to get the tranny out of the car first. The tranny has two halves which must be split apart in order to get to the shift forks.
Are you talking about how to get shift linkage un-done - the rolled-spring pin? You just need a 8mm non-tapered punch and a 10lb mini-sledge to get that bitch out.</TD></TR></TABLE>
Basically i just need to get the linkage off so i can pull the motor. I have a built long block waiting to go in.
Now that 8mm non tapered punch? i dont know what that is. Are you talking about pushing that "pin" thru so you can remove the linkage? its really hard to explain. if i had a pic....
Can i loosen that rubber boot. Then remove that clamp in the shape on a C. Finally push that block pin thru and the linkage should pull out? Is that correct or am i high?
let me know!
*edit* OMG i have 1337 posts now!
let me know!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">Basically i just need to get the linkage off so i can pull the motor. I have a built long block waiting to go in.
let me know!</TD></TR></TABLE>
Yes, you are correct...
Pull the boot back, remove the c-clip thing, and pound out the pin... use a non-tappered 8mm, or 5/16" punch, should slide right out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">dont mean to jack your thread but is the c clap thing nessacery when u put the pin back in?</TD></TR></TABLE>
It's there for a reason... and it's super cheap from Honda so you might as well replace it...
Your car will probably be fine without it but it's so easy to replace I wouldn't risk it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">i found it but when i was replacing my tranny i couldnt find it when i needed it so i said **** it. i want to put it on but i cant get under my car</TD></TR></TABLE>
so u have the c clamp now? or u still dont have it and u can't get under your car becuase.... its to low? if so just jack it up? and also i wouldnt run the rick of having my shift linkage come undo when i was driving and bend or mess up somting worse. its easy to pop in just move the rubber boot back and slip it on.
i have it but i cant get under my car cuz its too low and all the jacks i use are my friends and i dont want to bug them just for this little clamp. maybe if i just roll up onto something i can get under.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">i have it but i cant get under my car cuz its too low and all the jacks i use are my friends and i dont want to bug them just for this little clamp. maybe if i just roll up onto something i can get under.</TD></TR></TABLE>
JUST MAKE SURE YOUR CAR DOESNT FALL ON YOU!!!
