MIG welding and argon pressure
Old Apr 1, 2005 | 04:32 AM
EFSiR's Avatar
Default MIG welding and argon pressure
what pressure should I have the Argon on while mig welding with 308L 0.030"?
Old Apr 1, 2005 | 04:50 AM
fastcivicboy's Avatar
just put it at 25psi. thats what I put mine as. Anywhere from 20-30 should be fine.
Old Apr 1, 2005 | 06:40 AM
ssl2k's Avatar
25-30psi is overkill
16psi if your in an enclosed area with no wind.
only time you need 25-30psi is if you're outside in a field with wind.
Old Apr 1, 2005 | 07:02 AM
Want2race's Avatar
Default Re: (ssl2k)
i use 4cfm... my gauge is in cfm
Old Apr 1, 2005 | 07:09 AM
jaydmcrx's Avatar
Default Re: (Want2race)
25psi here. Works great.
Old Apr 1, 2005 | 07:24 AM
redzcstandardhatch's Avatar
something different
we mig weld pretty much every day, and indoors, in the garage, we just run it between 10 and 15 psi.
Old Apr 1, 2005 | 07:29 AM
99_GS-T's Avatar
What kind of CFM would that be roughly equivalent to?
Old Apr 1, 2005 | 03:15 PM
Engloid's Avatar
OG Fabricator
Default Re: (99_GS-T)
PSI is pressure, CFM is flow rate
You will have pressure in your bottle....read on one guage. the other guage will show FLOW.
probably 15-30cfm will be fine, depending on speed of travel, wind, etc.
sdubfid
Welding / Fabrication
Nov 2, 2009 03:27 AM
B18EG6
Dec 15, 2004 08:42 AM
fire7882
Sep 29, 2002 04:44 PM
rioninja
Sep 8, 2001 08:41 AM
