good cat for SMOGGING?
Old Apr 1, 2005 | 01:01 AM
GsR-Freak's Avatar
Default good cat for SMOGGING?
what is a good Cat for smog, i failed pretty dann bad, smog station stated that i need a new cat.
need suggestion of which cat to get JUST FOR SMOG. im looking for a good absorb cat for smog dont care about performance or bullsh*it...
2.5" inches cat
2.0
1.75
whatever
thanks all
Old Apr 1, 2005 | 02:15 AM
greasemonkee's Avatar
Default Re: good cat for SMOGGING? (GsR-Freak)
Is a stocker out of the question? If you've already got a cat, you might try running some Gumout Regane or some kind of fuel system cleaner and carbon remover through the system. Also, put a new set of plugs in and make sure the timing is dead on. All that will sure help.
Unless you've got some fire breather with poor fuel management, I would think most any new cat would do.
Old Apr 1, 2005 | 11:17 AM
PandaBear's Avatar
From what I heard hi flow cat is not good for smog because the flow rate is high and it doesn't allow enough time/surface to clean the exhaust before it leave the cat. Another thing to notice is if you are using a low quality cat it may not last as long. If stock cat is not so expensive I would recommend stock cat ($600 plus).
Old Apr 3, 2005 | 04:25 PM
GsR-Freak's Avatar
Default Re: good cat for SMOGGING? (PandaBear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear &raquo;</TD></TR><TR><TD CLASS="quote">From what I heard hi flow cat is not good for smog because the flow rate is high and it doesn't allow enough time/surface to clean the exhaust before it leave the cat. Another thing to notice is if you are using a low quality cat it may not last as long. If stock cat is not so expensive I would recommend stock cat ($600 plus).</TD></TR></TABLE>
i still have the stock exhaust system from my D16z6....but swap is a b18c1,,,i dont know if d16z6's cat would do it.
would soeone suggest a brand ....i prefer not to get any HIGH FLOW.
Old Apr 3, 2005 | 05:21 PM
Lord Helmet's Avatar
Catco that replaced my carsound cat that went to ****. Got it from summit racing.
Old Apr 3, 2005 | 11:40 PM
GsR-Freak's Avatar
Default Re: good cat for SMOGGING? (sleeperciv)
ttt
ekb16
Mar 1, 2005 09:06 PM
Canuk_SiR
Oct 30, 2003 08:50 AM
Thrillhouse
Jul 22, 2003 07:55 AM
96tegsr
Jun 17, 2002 11:44 PM
integraGSR213
Nov 1, 2001 03:27 PM
