itr ctr cam combo
i have heard of people using one of each like ctr intake and itr exhaust or vice versa i want to know wich set up works best or if i should just put in itr or ctr cams or if i am even on the right track
There would be no point since the CTR/ITR exhaust cams are the same, at least that's what I've gathered so I assume the have identical duration and lift. However the CTR intake cam has 3 degrees more duration than the ITR.
i have always used ctr intake and exhaust. btw 2001 itr intake cam is equivalent to ctr intake cam. just go with with ctr intake and exhaust its all uniform.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprinthart »</TD></TR><TR><TD CLASS="quote">i have always used ctr intake and exhaust. btw 2001 itr intake cam is equivalent to ctr intake cam. just go with with ctr intake and exhaust its all uniform.</TD></TR></TABLE>
00+ ITR and CTR are identical, Pre '00 ITRs have 3 degrees less duration.
