who here thinks they can put most B's and D series engine together with ease?
im just curious how many people on honda tech has the experience and knowledge to be able to assemble a B and D series engine bottom up if every little bolt and part was disassembled? Obviously a manual and specs sheet is needed in some instances but just overall who is capable or confident of their knowledge ans skills?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drip pan »</TD></TR><TR><TD CLASS="quote">They are not that hard. I can assemble one witn no trouble.</TD></TR></TABLE>
x2
x2
ive never tried assembling the entire engine together yet just replacing blown pistons. Plus i dont really have time cause im going to school.
as long as you have proper tools then it shouldnt be too hard...
ive disassembled a couple of motors....
id say the way to think about it is this. if your asking questions like "what parts do I need for a brake upgrade" or something general and that causes you trouble, then dont do it, cause you could seriously **** something up. If you are mechanically inclined, and have taken at least some auto tech, and know how engines work, some tricks, and have the helms manual, then go for it, because compared to other motors, the B and D are pretty simple engines. Remember than engines are finely tuned and don't like bend piston rings, but if you lube everything correctly and install properly, then you shouldnt have a problem.
MAKE SURE TO DO ALL YOUR HOMEWORK FIRST. I cannot stress this enough, as ive learned the hard way, and now that i spend hours researching every basic install, it is SO much easier. Do not assume that all parts are interchangable, check first.
fryman
16
May 18, 2008 10:44 PM
. why you ask?
