My Coupe doesnt run doesnt want to grab
okay...heres what happened...I was doing a burn out to get my tires warmed up at the race last night...and then I was about to run...I was reving it up and I was going to go and then I dropped the clutch and slammed the gas and it didnt move...
so when I try to drive the car normally it doesnt grab for ****...
the speedometer moves but my wheel isnt...
Its not the axles because it isnt spinning
when I start the car I have to push the clutch down ob course but after I start it I can put it in anygear without touching the clutch when the car is "ON"
im guessing my clutch is gone...if im wrong then tell me...
did the clutch just fell out of place...like not centered anymore??
tell me whatsup because im not to sure...
my clutch is basically still new...only had it for like 2 months...stage 3 ACT, 4 pucks with extreme pressureplate...
Some thing similar happened to me at the track twice. Once was when i sheered my axles, i could get the car in gear but i wouldn't got any where. The second time i blew the tranny, i could also put the car into gear with out using the clutch. Hopefully this didn't happen to you. Good luck.
Damn dude how do you people drive your cars? Sheered the axles? Popping trannys? Your clutch is two months old and you probably just blew it apart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blurrrcivic94 »</TD></TR><TR><TD CLASS="quote">We drive like ninjas
hahahahaha jdm ninjas i bet. you should just look at your car see if any thing looks out of place if not pull of your tranny.
</TD></TR></TABLE>hahahahaha jdm ninjas i bet. you should just look at your car see if any thing looks out of place if not pull of your tranny.
hahah...fucken **** grabs hard...stage 3 sucks guyz...stage 2 is way better...
my clutch broke...so yeah, thats the problem...I was about to run this b20V in a Integra...I would have lost but I wanted to see how my setup would hang...
jdmstyleEJ6
12
May 9, 2010 04:13 PM
