JDM H22 blowing white smoke
Old Mar 31, 2005 | 03:04 PM
integraa's Avatar
Default JDM H22 blowing white smoke
My JDM H22 blows white smoke when i stay in vtec like i hit vtec then let go and punch it again and it stays in vtec and then white smoke blows out.
Old Mar 31, 2005 | 03:21 PM
2point2's Avatar
Default Re: JDM H22 blowing white smoke (integraa)
your headgasket is probably blown.. check your coolant.
if your coolant is low than take of it ASAP.
Old Mar 31, 2005 | 08:04 PM
integraa's Avatar
Default Re: JDM H22 blowing white smoke (2point2)
yeah maybe the gasket. what do you mean by coolant, antifreeze?
Kyles ej1's Avatar
yup, same thing
Old Mar 31, 2005 | 09:05 PM
integraa's Avatar
Default Re: JDM H22 blowing white smoke (93ejay1)
the same thing happens to u
Old Mar 31, 2005 | 09:11 PM
EK k kay's Avatar
Check your oil for coolant in it.
Old Mar 31, 2005 | 09:14 PM
Cwhiteg6's Avatar
doesnt white smoke mean burning oil? maybe its bad rings....
Old Mar 31, 2005 | 09:19 PM
komat's Avatar
Default Re: JDM H22 blowing white smoke (civtecek9)
white smoke is coolant
black is fuel
blue is oil
Old Apr 1, 2005 | 12:28 PM
integraa's Avatar
Default Re: JDM H22 blowing white smoke (chowmien)
na no antifreeze in the oil.
Old Apr 1, 2005 | 02:34 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraa &raquo;</TD></TR><TR><TD CLASS="quote">na no antifreeze in the oil.</TD></TR></TABLE>
is your coolant full?
Old Apr 1, 2005 | 02:58 PM
integraa's Avatar
yeah i think so
Old Apr 1, 2005 | 03:18 PM
Kyles ej1's Avatar
how much smoke is it? like a real lot or like as much as when a car warms up
Old Apr 1, 2005 | 03:28 PM
Civic4less's Avatar
I thought black smoke was Fuel System Failure. A little bit of white was slight oil leak, a lot of white smoke was really bad oil leak, and blue smoke was coolant leak?
Old Apr 1, 2005 | 03:29 PM
blurrrcivic94's Avatar
Default Re: JDM H22 blowing white smoke (Civic4less)
my car puffs a little black smoke when I rev it high because I'm runninga little rich..
Old Apr 1, 2005 | 03:35 PM
modedicebox's Avatar
same symptoms of my car,yep you guessed it blown head gasket.
good luck
Old Apr 1, 2005 | 03:42 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: JDM H22 blowing white smoke (modedicebox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modedicebox &raquo;</TD></TR><TR><TD CLASS="quote">same symptoms of my car,yep you guessed it blown head gasket.
good luck</TD></TR></TABLE>
Get more information!
Is your car overheating, tell more about some actual signs of what beyond the white smoke is going on with the car.
Old Apr 1, 2005 | 03:56 PM
integraa's Avatar
Default Re: JDM H22 blowing white smoke (INVALID)
well theres no overheating. But when i rev it i think very very little or nothing of white smoke. Only when i hit vtec then let go of the gas and i stay in vtec and then let go of the gas then punch it again then a lot of white smoke comes out.
Modified by integraa at 5:27 PM 4/1/2005
Old Apr 1, 2005 | 03:58 PM
Kyles ej1's Avatar
have u done a compression or leak down check yet?
Old Apr 1, 2005 | 03:59 PM
Archidictus's Avatar
Unceasing Measure
It might not be a headgasket: it might be a cracked sleeve. You can check the inside of your valve cover for the infamous "head gasket icecream" that tends to develop wherever coolant and oil are being churned together...it's simple and an effective way to determine if you're burning water or antifreeze.
Old Apr 1, 2005 | 04:34 PM
integraa's Avatar
na i havent done a compression or leak down check yet
Old Apr 1, 2005 | 04:40 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraa &raquo;</TD></TR><TR><TD CLASS="quote">na i havent done a compression or leak down check yet</TD></TR></TABLE>
do those before u rip anything apart
Old Apr 1, 2005 | 05:22 PM
integraa's Avatar
alright ill do them then.
Old Apr 2, 2005 | 04:50 AM
symptoms of the blown head gasket on my car
1.oil residue in coolant reservoir tank
2.blowing white smoke under heavy accelartion
3.smell coolant after driving,but nothing leaking
4.foam in radiator
5.no overheating
hope this helps
Old Apr 2, 2005 | 10:10 AM
integraa's Avatar
oh alright thanks. Ill check that to. On mine u can smell gas on heavy acceleration sometimes and a little bit but may be its my bendy thing thats mest up and probably has a hole that connects the straight pipe thats why it sounds like its open header.
Old Apr 2, 2005 | 01:31 PM
integraa's Avatar
I checked for all the symtoms but none of them accept the white smoke. Theres no water in the reservoir i guess it went in the engine i dont know but i filled it up with antifreeze and water to the minimum and added antifreeze to the radiator to the top. I needed some more to fill it up to the top.
ELSUICIDA
13
Apr 4, 2007 06:07 PM
whatala
Sep 26, 2006 12:10 PM
1990civicsi
Aug 8, 2004 06:33 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
DANG YO
Nov 21, 2003 11:33 AM
