Turbo Oil Drain Size
Old Mar 31, 2005 | 01:22 PM
1FastCoupe's Avatar
Default Turbo Oil Drain Size
I went to a local performance shop and they were out of the -10an fittings for the oil pan but they had -8an fittings. I picked up the -8an fitting but I want to know if this will be big enough or do I have to go searching for the -10.. thanks
Old Mar 31, 2005 | 01:36 PM
Evanmb44's Avatar
Default Re: Turbo Oil Drain Size (1FastCoupe)
go with the 10 to be safe
Old Mar 31, 2005 | 03:04 PM
needaboosting's Avatar
Default Re: Turbo Oil Drain Size (Turboaddict)
Well also good info to know is if your running an oil restrictor or not. Even if you are not -8an should be more then enough unless the drain line is not pointed close to straight down(180degrees).
Old Mar 31, 2005 | 07:46 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">go with the 10 to be safe</TD></TR></TABLE>
deff. i would use -10
Old Mar 31, 2005 | 07:59 PM
1FastCoupe's Avatar
thanks for the info.. I was thinking because it relys on gravity for the oil to go down it would be better to use the 10. I need to just wait till i get the 10 and stop being in a rush to get the motor done..
Old Mar 31, 2005 | 08:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (1FastCoupe)
I would def. wait for the 10 fitting to come in, why risk it?
Old Mar 31, 2005 | 08:09 PM
1FastCoupe's Avatar
your def. right. It would be a shame to have put all this time , money and effort into a project to have a stupid fitting wreck it..
jdm-ray
Jul 2, 2005 09:29 PM
TurblowR
Jun 28, 2004 04:13 PM
zlambe
Jan 19, 2004 09:35 AM
Boostage
Jan 15, 2004 06:23 AM
ridnmyhonda
Feb 19, 2003 09:12 PM
