eg rear speakers
Old Mar 31, 2005 | 12:53 PM
mark_is_gay's Avatar
Default eg rear speakers
i got 2 tweeters and 2 speakers in teh front and i wanna put in 2 more in teh back my question is how can i wire this? can i run wires from the fron speakers to the rear? or if anyone have any wire diagrams for the speaker lay out on a stock hb 92? thanks
Old Mar 31, 2005 | 01:50 PM
Boxcar's Avatar
Default Re: eg rear speakers (mark_is_gay)
if there is not already wire there run it from your head unit or amp.
Old Apr 1, 2005 | 08:03 PM
Default Re: eg rear speakers (Back 2 Boxcar)
my friend told me to also run it from the head unit but can i really run it from teh amp? i think it would be easier cause my amp is under my chair so i can reach it iam not tryin to take out my head unit cause i dont kno how and dont want to **** up a 1g head unit ....... what wires do i gotta hook up to run the rear speakers from teh amp? where on the amp ?
Old Apr 2, 2005 | 11:38 AM
Camry's Avatar
i think it would be better to wire it up to the HU, cuz there's already wires there..
what kind of amp do you have??
what is the model and class?
Old Apr 2, 2005 | 12:56 PM
fcm's Avatar
fcm
Old Fart
Default Re: eg rear speakers (Camry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Camry &raquo;</TD></TR><TR><TD CLASS="quote">i think it would be better to wire it up to the HU, cuz there's already wires there..
</TD></TR></TABLE>Ditto that All Honda/Acuras come with rear speakers wired, evan if car didn't come with rear speakers, also if it's not a 4ch amp, [just a 2ch] then if you parallel the speakers 4OHM and 4OHM is 2OHMs and that may be to low for the amp, [maybe not] but you will not have any fade, [front to rear] and as you realy want less power to the rears the HU will have more then enough 94
Old Apr 4, 2005 | 11:35 PM
sumptimwong's Avatar
Default Re: eg rear speakers (fcm)
yups, there should be existing wires, and even the harnesses should be sitting under some stuff, waiting to be found. my eg sedan dx was the same way. once u lift up some panels, youll be able to see the speaker wires+harness pretty darn close to where the holes are to mount your speakers. gl
Ohbebe75
Audio / Security / Video
Aug 24, 2010 11:26 AM
mayfly
18
Jul 27, 2009 11:06 AM
akprelude99
22
Nov 26, 2007 05:02 AM
BoOsTiN Dc2
11
Mar 2, 2005 12:45 PM
HuGEN
Jul 14, 2001 02:51 PM
