First time dyno...opinions.
Old Mar 31, 2005 | 10:25 AM
RI_TM's Avatar
Default First time dyno...opinions.
3/30/05
Just got back from 3hrs. of work only...haha...and from the dyno.
Baseline(no tuning, no touching the motor)
185.5hp forgot torque...we forgot to printout the baseline.
After tuning All motor
201hp & 141.9tq
We tried to do the motor with nitrous and got one melted plug and a plug that flew like you wouldn't imagine!....the motor was still cool so we found two extra different plugs and just tried it. The #'s aren't too impressive but we'll see if we could try something else for the track.
#'s with nitrous (Bottle pressure at 800)
251hp & 213.8tq
I know there's a lot more with the nitrous so we'll see what it'll do at the track.
I forgot...all this was tuned with only VAFCII.
Tuned at CTR products in San Jose, CA (Chad Barber)
Set-up
LS/Vtec
B18A bottom end
Eagle Rods
Weisco Pistons (81.5 bore/11.5 compression)
Stock sleeves
GSR head
Milled 3thousands
Rev Valve springs & retainers
Blox Cams
Skunk2 manifold
94-95 prelude injectors(had no other choice...last minute thing)
Extra's
Jdm 4-1 headers(bolted up with exhaust during dyno)
digital 6
2 1/4 exhaust
I believe that's it.
Will try to post up Dyno graph as soon as i get a hold of a scanner.
Old Mar 31, 2005 | 10:30 AM
sheepey's Avatar
not bad bro i made around 230hp on a plate system on a BONE stock GSR motor.
Old Mar 31, 2005 | 11:00 AM
lovitalracer's Avatar
Default Re: First time dyno...opinions. (RI_TM)
Man you guys should be ripping it up out there . I have a header that will make good power if your interested . We can talk more at the track this weekend .
Old Mar 31, 2005 | 02:34 PM
RI_TM's Avatar
Default Re: First time dyno...opinions. (lovitalracer)
We'll see what we can do. This motor is in my daily driver car so i'm expecting low 13's to high 12's all motor and hopefully 11's on Nitrous.
Old Mar 31, 2005 | 04:01 PM
rjay8604's Avatar
Now head work (porting etc.)? milled .003 or .030? great numbers regardless.
Old Mar 31, 2005 | 04:50 PM
RI_TM's Avatar
Default Re: First time dyno...opinions. (rjay8604)
No head work.
Milled .030 i believe.
It's not bad #'s, We'll see what it'll do this weekend. If it doesn't rain.
Modified by RI_TM at 2:07 AM 4/1/2005
Old Mar 31, 2005 | 05:11 PM
RI_TM's Avatar
what compression would you guys think i'm at?
i'm guessing somewhere between 11.8 to 12.1?
Old Mar 31, 2005 | 05:57 PM
civicgsr19's Avatar
Default Re: (RI_TM)
Whats stage blox cams are you running, what degree settings did you end up with them, and is this where you made most of the power? Im asking because I want to see where most of the power is made in tuning. Thx.
And are your wiseco's the +5cc dome ones?
Old Mar 31, 2005 | 06:17 PM
RI_TM's Avatar
Default Re: (civicgsr19)
These were on Blox stage 2's.
I believe we made 201hp with the cam gears at 0,0. When we advanced the intake side we actually lost a little hp. (Not to sure what the problem was). It could be because of the milled head, but after that we changed out the plugs and tried nitrous. So i couldn't really answer your ?.
I'm not to sure on the dome #'s, but you can try looking on Wiseco's web site to see what 11.5 compression piston's dome is.
Old Mar 31, 2005 | 06:22 PM
civicgsr19's Avatar
Default Re: (RI_TM)
Thanks, so most of your power was made by timing and fuel changes. How do you like those blox cams? How many miles do you have on them?
Old Mar 31, 2005 | 06:54 PM
RI_TM's Avatar
We don't even have 1,000 miles on this new build! So far the Blox cams seems to be doing well. We'll see how it performs at CMI this weekend!
Old Mar 31, 2005 | 07:28 PM
slugzed's Avatar
very nice numbers...i like alot...can't wait to see it run @ cmi....good luck to everybody....
haha..mine only has about 10 miles on it..maybe less...it's gonna see hell this saturday and sunday..
Old Mar 31, 2005 | 07:49 PM
prestonpark's Avatar
Default Re: (geezer_o6)
u should hit mid 12 with no probelm allmotor
i didi it with my stock itr in a eg
191 133 on chad dyno
Old Mar 31, 2005 | 08:53 PM
civicgsr19's Avatar
Default Re: (RI_TM)
Sweet let us know, im building a similar setup for my 94 si, i have a b18a eagle rods, wiseco pistons, b16a head with RLZ engineering Stage 2 headwork, 98 USDM itr cams, rocket motorsports gen 2 valve springs and retainers. Im hoping to get 200 whp, but im thinking im going to need some bigger cams, i might be a little hard to hit 200 whp with the us itr cams.
Old Mar 31, 2005 | 09:59 PM
RI_TM's Avatar
Default Re: (THCBOOSTED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THCBOOSTED &raquo;</TD></TR><TR><TD CLASS="quote">u should hit mid 12 with no probelm allmotor
191 133 on chad dyno</TD></TR></TABLE>
Mid 12's?...Wow....i would be happy with just a high 12...haha...we'll see though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 &raquo;</TD></TR><TR><TD CLASS="quote">Sweet let us know, im building a similar setup for my 94 si, i have a b18a eagle rods, wiseco pistons, b16a head with RLZ engineering Stage 2 headwork, 98 USDM itr cams, rocket motorsports gen 2 valve springs and retainers. Im hoping to get 200 whp, but im thinking im going to need some bigger cams, i might be a little hard to hit 200 whp with the us itr cams.</TD></TR></TABLE>
You should be at 200. If you want cams...i recommend getting some blox...they're cheap and seems to make power
With a pair of cams, i'm pretty sure you'll get 200+.
Can't wait for CMI...*crossing fingers* hoping i don't dissapoint myself
Good luck to everyone who's going though...a lot of competition!
Old Apr 1, 2005 | 03:04 PM
civicgsr19's Avatar
Default Re: (RI_TM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RI_TM &raquo;</TD></TR><TR><TD CLASS="quote">
I am hoping, i really want some RM m22's. I think i shouldnt have a problem hitting 200 because my b16 right now runs like a bat out of hell and all i really have is the Headwork and itr cams.
oianarchy
Dec 11, 2006 07:09 AM
SD1222
Jun 6, 2006 06:31 AM
boosted k20
Jul 19, 2005 09:05 PM
#1151
May 10, 2005 03:01 AM
typeSwarrior
Feb 3, 2002 09:49 PM
