Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Endless or Hawk??
Old Jan 27, 2002 | 06:37 AM
Petah's Avatar
Default Endless or Hawk??
I am in the process of shopping for a set of pads for the coming summer. Last year, i had alot of trouble with brakes cause it always overheated on me!! This year, i plan on buying better pads hoping history would not repeat itself. I have done some research and many has recommended hawk blue as the pad of choice. The only problem to this is that i would need to swap pads and rotors evertime i hit the track which is very troublesome. Does anyone know if there is a Endless pad that will function just as well as the Hawk blue yet, daily drivable? I am already using Motul RBF 600. Thanks.
Old Jan 27, 2002 | 07:11 AM
krshultz's Avatar
Default Re: Endless or Hawk?? (eg-six)
Up at the top of the page on the right hand side there's a link that says "Search." You should click on it.
Since you asked...Carbotech Panther Plus. And not many of us (none of us?) have ever used Endless pads.
Old Jan 27, 2002 | 11:13 AM
Willard's Avatar
Preform as well... not sure.
But cost...
2 sets of Hawks ~ 1 set of Endless.
Will
Old Jan 27, 2002 | 09:03 PM
smp534's Avatar
New User
Default Re: Endless or Hawk?? (Willard)
In my experience and much of my fellow racer friend's experience... don't use endless!!!
[Modified by smp534, 6:04 AM 1/28/2002]
Old Jan 28, 2002 | 11:12 AM
MaddMatt's Avatar
Default Re: Endless or Hawk?? (smp534)
Do you still have the stock brakes on that thing?
There's no pad that does everything. Pather + pads are closest, but since they work best when they have some heat in them, the first couple of cold stops in the morning will be interesting. Plus, I've noticed a tendency to squeal under light line pressure (easy-moderate stops). They'll work on the street, but not ideal IMO.
The 3 most popular track pads: Hawk Blue, Carbotech Panther +, and Porterfield R4.
I have never heard or seen anyone take Endless pads on track. There might be a reason for that....
Old Jan 28, 2002 | 06:14 PM
GrasStrypa's Avatar
Default Re: Endless or Hawk?? (MaddMatt)
LIke i said in anther post panther + pads are the way for me, never tried ,hawks here good things thought. ont the street i use carbotech ss pads and there great street pads, thats on a 2 ton s-10 extreme
Old Jan 29, 2002 | 06:10 AM
Petah's Avatar
Default Re: Endless or Hawk?? (89civicZC)
No....i upgraded to GSR front brakes. I have narwoed my search into 3 products. Panther +, Hawk, blues, or Endless MA11. I am still debating which one of these i should get!
Old Jan 29, 2002 | 06:23 AM
matthewk's Avatar
How about 2 sets of front pads, something good for the street and then some carbotech panther XP's for the track, the pluses are good but I cooked them in a weekend at TWS.
Old Jan 29, 2002 | 09:31 AM
Petah's Avatar
Default Re: Endless or Hawk?? (matthewk)
OK.....after some calculations, it would be impossible to buy Carbotechs panther plus. Since i live in Canada, the shipping, taxes, brokage fees, and duties will end up costing more than endless pads!! So this narrows me down to 2 choices, Hawk blues or Endless MA11.....any inputs??
Old Jan 29, 2002 | 09:33 AM
SPiFF's Avatar
Hawk Blues are not streetable. They are the best track pad I have used to date though.
Old Jan 29, 2002 | 10:04 AM
MaddMatt's Avatar
Hmm. Well the GS-R brakes are better, but they're still pretty small for as much power as you have. Go with the Hawk Blues for track, and something not Hawk Blues for the street. That's probably as good as you can get right now.
Oh and if you haven't already, rid yourself of those heat retainers...I mean, splash guards on the rotors. That'll help a little.
Old Jan 29, 2002 | 11:10 AM
Petah's Avatar
How do you remove the splash guards? The bolts to those things are hard to reach......
Old Jan 29, 2002 | 11:13 AM
MaddMatt's Avatar
I'll have to leave that to someone that actually has a GS-R. Scott, Karl, how'd you guys remove those things?
Old Jan 29, 2002 | 03:35 PM
89civicdx's Avatar
Go with the blues...is nepean near ottawa? I drive at shanonville a lot and have no complaints about the blues. Why are you ordering from the us (shipping brokrage fees etc its just too much) get them from Toronto or there must be a race shop in ottawa. I don't know about the endless but I wouldn't want to spend money on a pad that no one has any idea about. If you want a pad for street and track you might want to try Hawk HP+, for me they squealed a lot but worked ok on the track. Now I use Blue though.
You don't have to totaly remove the brake shield you can trim most of it off with metal shears but may(its up to you) want to leave small sections around the lower ball joint and tie-rod end intact to help shield the balljoint & boot from heat.
[Modified by 89civicdx, 6:57 PM 1/29/2002]
Old Jan 29, 2002 | 05:02 PM
krshultz's Avatar
Here's how I did it. This may or may not work for you. I took a pair of needle nose pliers and got the screws to start loosening. From there it was pretty easy - I used a set of metal snips to cut them up, pried them out of there and installed them in the nearest trash can.
If that doesn't work...you're gonna have to pull the steering knuckle off the axle. That isn't hard - you'll need to pop the lower ball joint, and remove the big axle nut, and it'll slide right off the axle, granting you access to the screws holding the shields on. That's the way to do it if you don't want to cut the shields.
Old Jan 30, 2002 | 05:10 AM
Petah's Avatar
Default Re: Endless or Hawk?? (krshultz)
Thanks for the info. I will try that once winter goes away!! It;s too damn cold to be doing anything like this right now!
Old Jan 30, 2002 | 06:18 AM
MaddMatt's Avatar
Today's forcast high in Durham, NC? 80 F.
I can practically hear Spring already. If this not having a job thing didn't pay so lousy, it would RULE!
Old Jan 30, 2002 | 08:22 AM
Petah's Avatar
Default Re: Endless or Hawk?? (89civicdx)
Yeah.....like next door neighbours of Ottawa. Actually we merged into a mega city just like TO a year ago.
That is right! Shannonville is the track i hit......i have been up in Montreal (St. Estauche) as well, but it's not as good. I have only been on Fabi in Shannonville but this coming season, i willl hit Nelson as well! Should of seen the smoke pouring out of the brakes the last couple times i was at Shannonville....man enough is enough....Endless MA11s on order!
[Modified by eg-six, 9:23 AM 1/30/2002]
Old Jan 30, 2002 | 08:25 AM
Petah's Avatar
Don't rub it in.....i miss my car so much!!
Old Jan 30, 2002 | 12:10 PM
89civicdx's Avatar
Cool maybe I'll see you at a lapping day or somthing, how much were the endless?
Old Jan 30, 2002 | 01:26 PM
Petah's Avatar
$330, tax included. Not a bad deal considering that blues will run me $250 + tax. Yeah, maybe we will meet on the track, but i mostly organize my own track events (Sat. nights) cause it's the cheapest. Who do you usually go with?
Old Jan 30, 2002 | 06:09 PM
MaddMatt's Avatar
You guys must be HATING the exchange rate now. Blues will set me back $120 US shipped to my door.
Old Jan 31, 2002 | 10:47 AM
89civicdx's Avatar
Yeah $250 is around the right price unfortunately. I managed to get a set of blues for cost last year $180 cn but thats not going to happen again this year. I might try PFC pads and see how they are. I go with different people to lapping days...whoever is cheap and gives the most amount of time. sometimes this group http://www.geocities.com/image_racing1 maybe I'll come out to one of your days.
Maybe Matt can mail me a set then I don't have to pay outrageous brokerage fees
Old Jan 31, 2002 | 11:03 AM
Petah's Avatar
Sure.....but we are not that aggresive and have pretty strict rules. Safety is our first concern when it comes to lapping. Everyone would like to go home with their cars in one peice. If you want, you can email me for more details.
retep78@hotmail.com
[Modified by eg-six, 12:04 PM 1/31/2002]
ZUL8R
21
Mar 1, 2007 07:44 PM
magic hat #9
Apr 2, 2003 07:49 AM
Petah
Jan 30, 2002 10:31 AM
Petah
Sep 7, 2001 10:23 AM
