ITR front swap bar on ek dx, what front lca's do I need
IM thinking about getting an ITR front sway bar but I have a dx and it doesnt have holes for the endlinks and Ive searched and read that the ends are different and I was curious which ones I need.
On another note has anybody had there subframe tear using the srr sway bar tie bar kit for the rear on ek's?
Yes and aprently the LCA's off a HX will work too. Pictures can be found here http://www.jdmcivic.com/forums...58213
you can run si forks and LCA's.
I had a dx and I ran CTR LCA's and si forks. Great set up.
The JDM LCA's are much better than ours. Lighter and stiffer. I highly suggest them if you can find them...really not that hard to get. I sold mine long ago.
You can get the CTR LCA's front and rear, Si Forks, CTR rear LCA's and CTR front sway bar all for around $300. great upgrade on the DX.
Oh...and I'm pretty sure I have a comptech rear sway bar tie bar combo around that makes an even bigger difference. 96-98.
You CANT use the 99-00 Si LCA with the Type R sway bar! The end links are not compatable. You can use any 94+ integra LCAs, any 92-95 Civic w/ front sway LCAs, any 93-97 Del sol w/ front sway LCAs, or 96-00 EX LCAs. They are all the same exact parts on these cars...
In the following pics you can see the differences in the two LCAs & end links. The 99-00 Si has a special design that is incompatable:
00 ITR Lower Arms (bar #2 & end link #6)
99 Si Lower Arms
99 Si Lower Arms
SPOONfdEK
21
Aug 8, 2003 03:08 AM
