High pitched squeal after cleaning out TB and IACV
I recently removed and cleaned my throttle body and IACV and now whenever I start the car there is a high pitched squealing noise coming from the passenger's side of the engine bay near the firewall. The noise is so loud I can hear it distinctly in the cabin even with the windows up. The idle also hunts when warm going from 1500 to normal idle back and forth. The squealing noise goes away under acceleration.
All this got me thinking that there is a problem with the IACV, but any other suggestions as I've already tried removing the IACV and everything looks fine.
Thanks in advance.
Thanks in advance.
looks ok? you need to get some brake or carb clean and spray it around while the car is running & see if it bogs. if it does, then you found your leak.
Used the carb cleaner trick and found the leak at the TB gasket. There was a piece of old gasket the I didn't scrape off. Got out the razor blade and cleaned it off, put everything back together and the problem was gone
Thanks guys...
Thanks guys...
redline303
43
Nov 18, 2010 02:40 PM
AnAccordIsForever
Jul 13, 2006 11:52 AM
1990hondaHF
Aug 19, 2003 11:53 PM
