Odd idle with odd sound (searched..a lot)
I read most of the 112 topics about "idle" problems but none seemed exactly like mine. I have the typical loopy idle between 1000 and 1500 RPM but I also have an "air' noise that happens when the RMP's shoot back up. I also have the same noise with my CRX but that car has no problems . I only hear it when my CAI is on. It is higher pitches sucking noise. Related to problem? Oddly, this problem started shortly AFTER I cleaned off the throttle plate with carb cleaner. I'm going to clean off the IAC valve to see if that helps.
Re: Odd idle with odd sound (White Lightnin)
If its like a whistle, cleaning your throttle plate could have caused it. Now it has a sharper corner on it around the edge whereas before cleaning it was rounded due to buildup. Air flow is slightly more interupted at the edge of the plate and it might not be sealing as well when closed. The buildup of crud actually acts like a gasket sealing off the throttle plate but it also makes it sticky and eventually builds up too much causing more turbulence.
Re: Odd idle with odd sound (fred97gle)
The sound is comming from a selinoid of some sort not from an air leak. Like I said, CRX has the same noise. almost like it's letting air in or something...I'm sure the odd idle is connected to this somehow....
Re: Odd idle with odd sound (1990hondaHF)
have you read this thread:
https://honda-tech.com/zerothread?id=558236
I had an idle problem a while back. It might help lead you in the right direction. I would think the air noise is vacuum related somehow.
why don't you spray carb cleaner around the engine/intake area and see if the idle goes up. If it does then you have an air leak. Just be careful not to start a fire. Always a good idea to have a fire extinguisher on hand.
redline303
43
11-18-2010 02:40 PM
kevin7kevin7
07-11-2006 12:22 PM
