Help - Clutch Adjustment
Old Mar 30, 2005 | 07:38 PM
CRFdude83's Avatar
Default Help - Clutch Adjustment
I need a little bit of help if possible.
Recently my clutch has started to grab farther and farther out over the past 15k miles. Someone said you can adjust it, and someone you cant because it hydrolic not cable. Is there anyway i can adjust where it grabs at?
BTW - 95 lx with 112k
Thanks.
Old Mar 31, 2005 | 04:10 AM
JimBlake's Avatar
Default Re: Help - Clutch Adjustment (CRFdude83)
It's self-adjusting, but it sounds like your clutch disk has gotten too thin for the range of self-adjustment. You better start shopping for a new clutch.
Old Apr 7, 2005 | 10:38 PM
pearlcfcivic97's Avatar
would that mean its all the way at the top or the bottom, sorry im having a brain fart
Old Apr 8, 2005 | 03:32 AM
everlasting1832's Avatar
you can adjust the clutch pedal and the clutch master cylinder. i read about it in the Honda Accord Clinton Book. scoop one up at O'reillys for 10 bucks
Old Apr 8, 2005 | 09:34 PM
Schmitey's Avatar
Default Re: Help - Clutch Adjustment (everlasting1832)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everlasting1832 &raquo;</TD></TR><TR><TD CLASS="quote">you can adjust the clutch pedal and the clutch master cylinder. i read about it in the Honda Accord Clinton Book. scoop one up at O'reillys for 10 bucks</TD></TR></TABLE>
did you not read a damn thing JimBlake just wrote?
yeah man, get a new clutch before the car stops moving!
Old Apr 8, 2005 | 11:23 PM
phateless's Avatar
feel around behind your clutch pedal. there's a little nut on the master cylinder that lets you adjust the clutch pedal postion. REALLY REALLY simple!!! 5 minute operation, tops. all you'll need is a couple of (i think) 12mm crescent wrenches
Old Apr 9, 2005 | 07:14 AM
deserthonda's Avatar
by adjusting the clutchpedal height at master cylinder you are putting a band-aid on a 5 inch scar it will just buy you a little extra time , and afterward if you pot a new clutch you have to readjust it again
Old Apr 9, 2005 | 07:23 PM
Schmitey's Avatar
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">by adjusting the clutchpedal height at master cylinder you are putting a band-aid on a 5 inch scar it will just buy you a little extra time , and afterward if you pot a new clutch you have to readjust it again </TD></TR></TABLE>
second that
Lissa1322
Jan 1, 2018 10:39 AM
Stonage07
Mar 6, 2017 11:48 AM
Youshady2
Oct 21, 2013 01:54 PM
LSEGHATCH
May 2, 2006 06:18 AM
gsr camel
Sep 13, 2001 12:05 PM
