Suspension & Brakes Theory, alignment, spring rates....
Bouncy as hell, what do i do?
Old Mar 30, 2005 | 07:30 PM
SilverCIVI's Avatar
Default Bouncy as hell, what do i do?
Hey, I just bought some tein springs and put them on AGX's. This gave my 98 EX Civic a nice ride height but it bounces like crazy. Any ideas as to what is causing my dilema?
Old Mar 30, 2005 | 08:38 PM
skunk2finatic's Avatar
Default Re: Bouncy as hell, what do i do? (SilverCIVI)
bouncy is better than slammin the pavement every time you hit a bump....lol
I got that problem right now...I'd love to have a bouncy suspension..
Old Mar 31, 2005 | 07:59 AM
SkankyEJ7's Avatar
what setting do you have them on, and is it like stiffy bouncy or hydrolyics bouncy
mine rides just fine on agx's and intrax springs, im gettin GC's soon
Old Mar 31, 2005 | 08:40 AM
ki3t's Avatar
This user can set his title.
Change your settings?
or
it could be that your spring rate sucks?
Old Mar 31, 2005 | 08:41 AM
purplegsr's Avatar
Default Re: Bouncy as hell, what do i do? (hondakid1)
Did you cut your bumpstops?
Old Mar 31, 2005 | 08:45 AM
panix's Avatar
Default Re: Bouncy as hell, what do i do? (purplegsr (Exospeed))
What would happen if u didn't cut ur bump stops... cuz stupid me put skunk2 coilovers on and didn't cut the bump stops? I don't have any problems just the bumpiness which don't bother me at all. Should i cut them or take the totally off ??
Old Mar 31, 2005 | 08:54 AM
purplegsr's Avatar
Default Re: Bouncy as hell, what do i do? (panix)
If you don't cut your bumpstops by about an inch, you can run the risk of 'riding' on them, which will cause a bumpy ride. You want a balance between protecting your shocks from bottoming out (no bumpstop) and always having your car sitting on the bumpstops because the car is too low and your bumpstop is too long (not cutting them at all).
Old Mar 31, 2005 | 09:16 AM
suspendedHatch's Avatar
What setting are the AGXs on? Full I'm guessing. Try one or two. Not that the adjustment on AGXs make much difference anyway, POSs.
Old Mar 31, 2005 | 10:01 AM
panix's Avatar
so are u saying i should jack my car up and cut my bumpstops about an inch?? or just rip them off??
Old Mar 31, 2005 | 10:05 AM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panix &raquo;</TD></TR><TR><TD CLASS="quote">so are u saying i should jack my car up and cut my bumpstops about an inch?? or just rip them off?? </TD></TR></TABLE>
cut a little bit off, but if it's not bothering you, don't worry about it. Definitely don't rip them off completely though. The shock isn't designed to bottom out, that's why bumpstops are there to stop the piston from going all the way down.
Old Mar 31, 2005 | 10:11 AM
panix's Avatar
good ****... thanks a bunch
Old Mar 31, 2005 | 06:00 PM
SilverCIVI's Avatar
Default Re: Bouncy as hell, what do i do? (ki3t)
Do you think that maybe the spring rates are too high for my car, or do you think that they might be too low? I have already tried all kinds of adjustments on the shocks, i have 4 ways on the front and 8's on the rear and nothin' seems to work all that well.
Old Apr 1, 2005 | 05:25 PM
The AGXs can probably handle around 350 max. If your spring rates are higher than that, then congratulations your springs are under damped.
Either that or you dont have any suspension travel left.
94_Teggy
Feb 17, 2009 11:00 AM
91Ef4dR
Oct 21, 2008 01:36 PM
Metal Head
Suspension & Brakes
Apr 19, 2007 08:01 AM
clutch33
Jul 31, 2004 09:19 AM
MarkZeroNine
Jul 2, 2003 11:45 PM
