wire feed installation help
Old Mar 30, 2005 | 06:09 PM
14bcoupe's Avatar
Default wire feed installation help
ok i bough a mig-100 flux wire welder
but im having a real tough time getting it to work.
i feed the wire through but its not coming out.
anyone have a step by step cause the instruction
in the manual are the shortest ever.
Old Mar 31, 2005 | 03:55 PM
14bcoupe's Avatar
Default Re: wire feed installation help (14bcoupe)
anyone?
Old Mar 31, 2005 | 04:22 PM
RCautoworks's Avatar
Is the wire spinning when you press the trigger, the wire might be to tight or to loose on there.
Old Apr 1, 2005 | 09:57 AM
14bcoupe's Avatar
Default Re: wire feed installation help (90blackcrx)
ok rechecked it and the wire moves the opposite way, intead of feeding to the torch it goes back to the wire loom. is the welder mess up or am i doing something seriously wrong?
Old Apr 1, 2005 | 11:13 AM
dfoxengr's Avatar
does the spool actually spin or are there 2 clamped round dies that spin, with the wire going through them?
Old Apr 1, 2005 | 11:31 AM
david@didrace.com's Avatar
If the wire is getting pushed back onto the spool your two trigger wires are on the opposite connections.
Old Apr 1, 2005 | 11:38 AM
dfoxengr's Avatar
Default Re: wire feed installation help (backpurge)
reverse polarity sucks donkey nuts.
from my post above, if the actual spool is spinning (meaning the spline in the middle turns the spool) then i hope you have the good sense to turn the spool upside-down
Old Apr 2, 2005 | 09:58 AM
14bcoupe's Avatar
Default Re: wire feed installation help (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">does the spool actually spin or are there 2 clamped round dies that spin, with the wire going through them?</TD></TR></TABLE>
yeah man its the 2 clamped round dies that spin
Old Apr 2, 2005 | 09:59 AM
dfoxengr's Avatar
then you must have the polarity reversed
Old Apr 2, 2005 | 05:14 PM
14bcoupe's Avatar
ok thankz i will check that,hope thats the problem, i need to get this thing working my muffler is just too loud cause of a little hole it has.
Old Apr 8, 2005 | 04:19 PM
14bcoupe's Avatar
yep it was reverse. thank you guys
now any tips on trying to weld, it seems hard as hell when i tried it.
Old Apr 8, 2005 | 05:14 PM
Practice practice practice, then when your tired, force yourself to practice some more... jk never weld when tired
Old Apr 19, 2005 | 11:20 AM
14bcoupe's Avatar
thankz man im practicing, just slighly getting the hang of it sort of
San-Wan
Sep 30, 2008 07:28 AM
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
5STAR3
Jan 22, 2004 03:47 PM
