DUSTIN - WHAT IS THIS ON YOUR TURBO???????
Yeah, you should have one in your Drag kit. In fact, there should be two: one for the side port of your WG and one for the compressor. I connected a hose from that port to the bottom port of my Greddy Type S BOV and the top port to my intake manifold for better BOV response. You could also use it if you had an EBC like the AVCR or something.
just make sure that you connect the wastegate to some kinda strong vacume sorce or it will be nasty
noe more question. I notice the teflon tape is used on oil feed fitting which is not reconmond in drags installation manual, qoute "7) Install the 90 degree "AN" fitting to the center section (DO NOT use any Teflon tape and/or silicone on the fitting)"
So should I use the teflon tape or not??
You use teflon tape on NPT fittings, not AN fittings. AN fittings seal by pressure at the bevel, NPT fittings seal at the threads...
Dustin
Dustin
so it that vacuum source what you use for your boost controller? im still hesitating to put my boost controller on cuz if i mess up, i might blow my motor.
Dustin I think you circled those Earl's fittings for me. We ordered them at the same time, but you got yours first. You were showing me how freakin LONG the barbed part of the fitting is. I'm still using the same ones!
[Modified by dangerzone, 8:29 PM 1/28/2002]
Civic Racer X 7
May 27, 2007 09:07 AM
