DUSTIN - WHAT IS THIS ON YOUR TURBO???????
Old 01-26-2002, 11:21 PM
intekragsr's Avatar
Default DUSTIN - WHAT IS THIS ON YOUR TURBO???????
what is this little piece that is circled? It didnt come with my kit, I dont think. Do I need it?
Old 01-26-2002, 11:23 PM
bigTom's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (intekragsr)
its just a vaccumm source... and no u dont need it
Old 01-26-2002, 11:26 PM
Better than steak
Arturbo's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (Tom)
I think the drag kits come with a brass fitting.
Old 01-26-2002, 11:39 PM
Giuseppe's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (Arturbo)
thats a pressure source usually for turbos with an integrated
wastegate,
i guess in your case u have an external one...
Old 01-27-2002, 06:07 AM
maxim's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (Giuseppe)
Yeah, you should have one in your Drag kit. In fact, there should be two: one for the side port of your WG and one for the compressor. I connected a hose from that port to the bottom port of my Greddy Type S BOV and the top port to my intake manifold for better BOV response. You could also use it if you had an EBC like the AVCR or something.
Old 01-27-2002, 08:34 AM
Ri5e's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (maxim)
Maxim, how much more response did you get with the Bottom port on the Blow off valve connected to the Turbo compressor??
Thanks.
Old 01-27-2002, 10:12 AM
PROFILES2000's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (BG Boost)
just make sure that you connect the wastegate to some kinda strong vacume sorce or it will be nasty
Old 01-27-2002, 10:17 AM
bigTom's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (PROFILE GSR)
yea... someone i know didnt do this... now their rebuilding their motor!
Old 01-27-2002, 02:36 PM
miller's Avatar
yup yup
Old 01-27-2002, 02:43 PM
New User
dangerzone's Avatar
noe more question. I notice the teflon tape is used on oil feed fitting which is not reconmond in drags installation manual, qoute "7) Install the 90 degree "AN" fitting to the center section (DO NOT use any Teflon tape and/or silicone on the fitting)"
So should I use the teflon tape or not??
Old 01-27-2002, 07:34 PM
New User
degradated's Avatar
I'm pretty sure teflon tape is safe to use and should be used on anything except for fuel lines...
Old 01-27-2002, 07:47 PM
dustin's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (degradated)
You use teflon tape on NPT fittings, not AN fittings. AN fittings seal by pressure at the bevel, NPT fittings seal at the threads...
Dustin
Old 01-27-2002, 10:12 PM
New User
SIK IN DA HED's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (dustin)
so it that vacuum source what you use for your boost controller? im still hesitating to put my boost controller on cuz if i mess up, i might blow my motor.
Old 01-27-2002, 10:16 PM
philo's Avatar
why would your waste gate need to see vacuum?
Old 01-27-2002, 10:45 PM
dustin's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (dlplayboy)
Better take your turbo off too, cause that might contribute to a blown motor...
Old 01-27-2002, 11:13 PM
New User
dragonsmp's Avatar
haha...
Old 01-28-2002, 10:00 AM
New User
HA HA HA very funny, dustin.
Old 01-28-2002, 10:43 AM
Seraph0's Avatar
Dustin I think you circled those Earl's fittings for me. We ordered them at the same time, but you got yours first. You were showing me how freakin LONG the barbed part of the fitting is. I'm still using the same ones!
Old 01-28-2002, 11:27 AM
New User
dangerzone's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (MarkC)
yeah, that fitting is too long. I try to screw it on the compressor housing port but it hits the turbo inlet. any tricks to make it fit??
[Modified by dangerzone, 8:29 PM 1/28/2002]
Old 01-28-2002, 10:57 PM
dustin's Avatar
Default Re: DUSTIN - WHAT IS THIS ON YOUR TURBO??????? (dangerzone)
Cut it off?
Civic Racer X 7
05-27-2007 09:07 AM
xiLLtegRax
11-27-2005 04:15 PM
Ricey McRicerton
09-23-2003 04:04 AM
maxim
01-14-2002 11:09 PM
JohnShaft
08-22-2001 11:10 AM
Quick Reply: DUSTIN - WHAT IS THIS ON YOUR TURBO???????
