First Dyno ever
Old Mar 30, 2005 | 04:50 PM
95GSRT's Avatar
Default First Dyno ever
This afternoon was my first dyno session. I need your thoughts. My setup is:
Drag mani
Turbo (GT3255E)
tial 38mm wastegate(8psi spring)
rc550's
Custom fmic
greddy type s bov
Hondata S200
drag ic piping
walbro 255 fuel pump
drag 2.5" dp
for now a stock itr exhaust
I made 242.0whp with 169.2ft/lbs @ 8psi
Tell me what you think.
Old Mar 30, 2005 | 04:58 PM
alpha's Avatar
Default Re: First Dyno ever (95GSRT)
Sounds good At what RPM did you see 8lbs?
Old Mar 30, 2005 | 05:05 PM
95GSRT's Avatar
Default Re: First Dyno ever (0x64)
Full boost at around 3000rpm. This turbo spools like a bitch. And keeps going. I want to up the boost though
Old Mar 30, 2005 | 05:06 PM
oxSLEEPERxo's Avatar
you might free up some more hp if you get a better exhaust. Was that dyno with a stock catylac convertor?
Old Mar 30, 2005 | 05:07 PM
95GSRT's Avatar
Default Re: First Dyno ever (oxSLEEPERxo)
no cat at all. I know my exhaust is killing me
Old Mar 30, 2005 | 05:08 PM
frago's Avatar
Torque seems low, why do you suppose that?
Old Mar 30, 2005 | 05:09 PM
95GSRT's Avatar
Default Re: (frago)
I have no idea why my torque is so low
Old Mar 30, 2005 | 05:13 PM
alpha's Avatar
Yes. It's a great all around turbocharger that's not going to break the bank You can turn up the boost some more but I am sure you are happy with it as is. The exhaust, along with a couple other things, is hurting your torque and horsepower but as I said above you should be happy for now.
Old Mar 30, 2005 | 05:17 PM
95GSRT's Avatar
I want to turn up the boost a bit I am looking for a 10psi spring right now. This dyno is a mustang dyno, and I heard that you have to add a bit more power to get the equivelancy of a dynojet. Is this true?
Old Mar 30, 2005 | 06:08 PM
spectacle's Avatar
Default Re: (95GSRT)
umm...what motor is it?
Old Mar 30, 2005 | 06:25 PM
Default Re: (spectacle)
from his username, its a b18c1
Old Mar 30, 2005 | 06:55 PM
Tapen00n's Avatar
Default Re: (oxSLEEPERxo)
torque is low because you have no cat, more flow means less backpressure
Old Mar 30, 2005 | 07:04 PM
turboEGhatch's Avatar
Default Re: (Tapen00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tapen00n &raquo;</TD></TR><TR><TD CLASS="quote">torque is low because you have no cat, more flow means less backpressure</TD></TR></TABLE>
lol, no. Backpressure has nothing to do with it, backpressure has nothing to do with it in an N/A car. If anything having no cat would make more torque, because the turbo would spool quicker.
Old Mar 30, 2005 | 07:23 PM
Mr.DC2TurBo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRT &raquo;</TD></TR><TR><TD CLASS="quote">This afternoon was my first dyno session. I need your thoughts. My setup is:
Drag mani
Turbo (GT3255E)
rc550's
Custom fmic
greddy type s bov
Hondata S200
drag ic piping
drag 2.5" dp
Tell me what you think. </TD></TR></TABLE>
242hp at 8psi on a GSR motor is really low? If it's on a LS then that's about right
Old Mar 31, 2005 | 03:45 AM
95GSRT's Avatar
Default Re: First Dyno ever (Mr.DC2TurBo)
My tuner said that if I ditch my piece of **** exhaust and put 3" piping it will be a dramatical increase in hp. he said around 10hp. as well it's on a conservative tune so the timing is not too advanced. He put it for a very streetable tune, not too aggressive. I'll go back with my new setup and then we will see.
Old Mar 31, 2005 | 05:56 AM
Benjithx's Avatar
if you only had a stronger block......
sorry, I am itching for an STI
Old Mar 31, 2005 | 08:06 AM
95GSRT's Avatar
Default Re: First Dyno ever (Benjithx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx &raquo;</TD></TR><TR><TD CLASS="quote">if you only had a stronger block......
sorry, I am itching for an STI</TD></TR></TABLE>
Funny. I'll just mess around with this one till she blows and then buy a built block. Dont worry Benjithx you'll sell it, There are plenty of people who need a sleeved block.
Old Mar 31, 2005 | 08:35 AM
Cashed EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
242hp at 8psi on a GSR motor is really low? If it's on a LS then that's about right </TD></TR></TABLE>
242hp @ 8psi on a GSR is not low on a Mustang Dyno.
Old Mar 31, 2005 | 08:40 AM
95GSRT's Avatar
what is the usual hp difference on the 2 dynos?
Old Mar 31, 2005 | 08:55 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">you might free up some more hp if you get a better exhaust. Was that dyno with a stock catylac convertor?</TD></TR></TABLE>
might? WTF....that right there would be like a 20whp gain.....
Awsome man...
But I'm also betting money that you don't see 8si by 3000rpm's with that exhaust and 2.5" Downpipe......
Old Mar 31, 2005 | 09:09 AM
trentepic's Avatar
Default Re: First Dyno ever (m R g S r)
be carefu wid ur a/f ratio if u change the exh, if it makes a big difference flow wise and if it hurting u so much now, u can bet it will effect the a/f ratio dramatically.
-Toby
Old Mar 31, 2005 | 10:18 AM
jthm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Yes. It's a great all around turbocharger that's not going to break the bank You can turn up the boost some more but I am sure you are happy with it as is. The exhaust, along with a couple other things, is hurting your torque and horsepower but as I said above you should be happy for now.</TD></TR></TABLE>
Arent these turbos around 750.00 new?
Old Mar 31, 2005 | 10:31 AM
TuRbO_CrX_7o2's Avatar
mustang dyno = 3-4 % less then dynojet
my dyno (b18c, eagle rods, stock comp je pistons, drag kit @ 10psi)
279 whp @ 7200 rpm
218 ft lbs @ 6800 rpm
best time so far is 11.7 @ 116 mph w/ my girlfriend in the car video tapping
the track is open tonight, hopfully better times today....
this is in a 89 crx si
(15 x 24.5 welds)
the car went 11.9 @ 113 w/ 8psi with the stock motor last year, finally blew after 2 years.... was only making 235 whp and 181 ft lbs on a dynojet ( rings were going)
Old Mar 31, 2005 | 01:39 PM
95GSRT's Avatar
Default Re: (TuRbO_CrX_7o2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
But I'm also betting money that you don't see 8si by 3000rpm's with that exhaust and 2.5" Downpipe......</TD></TR></TABLE>
I will double check, but I'm pretty sure it's not many more rpm if any.
Old Mar 31, 2005 | 02:08 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TuRbO_CrX_7o2 &raquo;</TD></TR><TR><TD CLASS="quote">mustang dyno = 3-4 % less then dynojet</TD></TR></TABLE>
Mustang Dyno can do unloaded (Dyno Jet) numbers. I have found a 5% - 7% difference in power between loaded and unloaded pulls on a Mustang Dyno. It seems like people on here think Dyno Jet's are superior to Mustang Dyno's
