sounds like loose change in my motor...
My motor sounds like there is loose change up in it jingling around. I have replaced the dis cap and rotor and that didn't solve it so I figured it was loose valves but I adjusted them today and it still makes the damn noise. I was hoping someone on here would be able to help me figure out this problem.
thanks,
-Garrett
thanks,
-Garrett
could be anything from loose exhaust heat-shields to major engine issues to a craked exhaust manifold.. the best thing you can do is to get an automotive stethiscope (about 12 bucks at a parts store) and start really listening for it. If its a water pump or accessory drive part they sound like ice being choped in a blender when the bearings go bad..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRerrr »</TD></TR><TR><TD CLASS="quote">got the same problem, how do u fix a loose valve. i still gota check if its my heat shield but cant tell if its from engine or under me..</TD></TR></TABLE>
to "fix" a loose valve is to get a valve adjustment job....
Azxster
Aug 8, 2006 08:19 AM
