SUPER CHARGER QUESTION
Old Mar 30, 2005 | 10:46 AM
djsin's Avatar
Default SUPER CHARGER QUESTION
Would a Jackson Supercharger be worth buying. My car is a daily driver so, I wanted to know if it would be bad to have it? I have a exhaust, AEMV2 intake, DC HEADERS and a VFtec controller.
Old Mar 30, 2005 | 10:47 AM
latindc2's Avatar
no it wont be bad to have it, keep up the maintence(sp) and u good, if u got the money then go for it, do u even know how supercharger work?
Old Mar 30, 2005 | 10:49 AM
djsin's Avatar
Default Re: (latindc2)
yeah, but just was wondering if it would be worth buying. Was going to go turbo but, wanted to make my car street legal.
VINtegra90's Avatar
Default Re: SUPER CHARGER QUESTION (djsin)
how much is a supercharger anyway like $3k?
Old Mar 30, 2005 | 10:52 AM
djsin's Avatar
Default Re: SUPER CHARGER QUESTION (VINtegra91)
yeah with installation and all.
TeaAddict's Avatar
greddy has a kit that is "street legal" it doesn't have FMIC.
Old Mar 30, 2005 | 10:56 AM
djsin's Avatar
Default Re: SUPER CHARGER QUESTION (TeaAddict)
whats FMIC?
Old Mar 30, 2005 | 10:58 AM
latindc2's Avatar
Front mount intercooler Yo!
Old Mar 30, 2005 | 11:00 AM
djsin's Avatar
Default Re: SUPER CHARGER QUESTION (latindc2)
yeah thats true. You get a better gain of power out of a turbo too. Might consider but, im not sure yet. I don't really race on the track and drive my car daily.
Old Mar 30, 2005 | 11:01 AM
latindc2's Avatar
Then save your money and just buy bolt on's.
Old Mar 30, 2005 | 11:03 AM
djsin's Avatar
do u have turbo in your car?
Old Mar 30, 2005 | 11:04 AM
latindc2's Avatar
me? no only bolt on....daily beater
Old Mar 30, 2005 | 11:24 AM
TeaAddict's Avatar
check the FI (force induction) they can help you chose turbo or supercharge. why do you need more power for your daily driver?
Old Mar 30, 2005 | 12:25 PM
Medek's Avatar
Researching more into what a supercharger and a turbo actually do to your ride and how they work, will aid in your ultimate decision. Some basic things you may or may not know are:
I am not a professional, just an enthusiast. So please take into consideration that comments are my own and may not be completly accurate.
supercharger: the added power is immediate. the charger works off of your cars crank and pully system. so when the crank is spining your getting that power immediatly. because the charger works off of the crank, it's looses some power through the belts, as an end result. The charger basically sucks air into the engine. With the charger, you'll see the most power gain in the lower RPM range, but dies off in the higher RPM range. I'd say between 1-3K RPM is peak area for a charger. Many people argue that charging a teg isn't so great since our b18's are higher revving engine's (7-8K).
Turbo: works on exhaust gases. depending on your turbo and it's size it can kick in full spool at anywhere from 2K RPM to 3K or above. Basically it bolts on the exhaust side of the engine and takes time to fully spin. so you wont feel it "instantly". Alot of people reccomend the turbo on a b18 engine simply because it's more efficent and makes more power lbs. for lbs. Besides, it doesnt take very long to reach 2-3K on a b18 anyways. And a proper sized turbo can make power all the way untill your redline and then some.
Anyways, it's really up to you and for what your looking for. And im sure there's much more benfits and downside to each application. Some say the chrager is less maintenance, with less parts likely to fail. Some say chargers suck because of the engine style. Also take into consideration your power goal. where do you wnat to be and can you make it reliably with what form of FI.
food for thought...
Old Apr 1, 2005 | 11:49 AM
djsin's Avatar
Default Re: SUPER CHARGER QUESTION (Medek)
right on for the info.
Old Apr 1, 2005 | 12:39 PM
uLTrAvTEc757's Avatar
i have a 9lb. jrsc on my gsr that i drive daily (when its not in the body shop). i like it, i've had turbo cars before, including a turbo teg, the jrsc is a nice change, it's not the fastest thing in the world, but it does make some decent power and it's fun to drive to work. hope this helps you some
Old Apr 1, 2005 | 12:56 PM
Finger Lickin' good's Avatar
Default Re: SUPER CHARGER QUESTION (uLTrAvTEc757)
its like this. Get the supercharger if you dont have a big ego and can take getting beat by a neon srt4. Turbo if you have a huge ego and cant loose. or something.
Old Apr 1, 2005 | 04:16 PM
integragsr33's Avatar
go super if you want a good daily driver. less headache
Old Apr 1, 2005 | 05:25 PM
BlackSage's Avatar
What car do you have? Year, model, and trim please. Since you live in CA you have to think about SMOG
Old Apr 1, 2005 | 06:27 PM
IggyBcool's Avatar
the jackson racing cant have a fmic because it bolts directly up behind hte block. also with the JRSC you'll only be pushing 210whp vs a vortech's 286hp....think about it and they almost cost the same well...maybe about a grand more but totally worht it. or u could even go with the Procharger with the stock 9lb pulley that comes with the kit you'll be pushing 308whp with proper tuning. and it even comes with an intercooler not an aftercooler that comes with the vortech.
Azcheron
Honda S2000
16
Mar 25, 2007 11:40 AM
tanabedc2
Nov 27, 2005 01:37 AM
RedRacer
Jan 14, 2005 09:14 PM
TegDude
Oct 21, 2004 05:50 PM
Ablahad
Aug 21, 2001 09:51 PM
