Just replaced clutch....still having trouble...
I had just recently replaced my clutch it just completly gave out. I was unable to get the car into gear. and so i bought a full clutch kit and had it installed last week. and its not a clean shift at all its almost like how it was before but a little stiffer. For a good while i couldnt get my car in gear when i was stuck in traffic then it came...ummm im thinking master cylinder is a worn or needs replacement. what do u guys think...all comments appreciated...
Master Cylinder? What are you talking about? There are master cylinders on <U>hydraulic</U> transmissions, NOT cable transmisions! You might be in the wrong forum if you think its the master cylinder.
If you have a cable transmission, check the clutch cable. I hope when you replaced the clutch you had the flywheel resurfaced and put the clutch and pressure plate back on correctly. I hope you also changed the pilot and release bearings. I lastly hope you changed the transmission fluid.
i requested for the flywheel to be resurfaced but my mechanic said their was no need to resurface the flywheel. he said it was in good shape. i changed fluid and bearings all that ..
also you might have a problem like i read about on http://www.thezcr.com , he had a problem witht he clutch cable stretching when it got hot.
Wait...nevermind
Wait...nevermind
I like this one - Clutch Break-In.
But in all reality if you search for Clutch Break in the archives you will find many others.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">I like this one - Clutch Break-In.
But in all reality if you search for Clutch Break in the archives you will find many others.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip »</TD></TR><TR><TD CLASS="quote">Try adjusting the clutch cable..mine used to do the same thing, and i adjusted it, and it was like new. Make sure you turn it clockwise though.</TD></TR></TABLE>
TuwboBuddy
May 3, 2006 07:40 PM
